Going wide or going high?
Hello Polk users!
I recently move to an appointment and I have some questions regarding my Polk speakers placement (tsi500, 200,100 and center Cs20). My receiver is an onkyo txnr709 and have 7.1. My question is, do I go to the front wall wide or high? I know I suppose to don't put speakers on the back because my Soffe is against the wall. Thank you in advance and I am a big Polk fan!
Post edited by zorrier on
I hope I was clear enough about my question and my layout.
The #2 and 3 are the amount of people that can be fit on the sofa.
Room dimensions would help. Heights at least 2 feet outside mains, and as close to ceiling as possible. Wides ideally 165 degrees at sweet spot
Wouldnt it be best to use the room long ways? As in tv either in front of window or have it divide the room at the other end where the kitchen is? I think ur too close to the speakers and tv where everything is now.
Surround usually to each side of the listening area about 2 feet above ear level pointing at each other. If the tv was at either end putting up surrounds wouodnt be that hard.Full 5 channel set of Polk Audio
Fronts - LSiM 705
Center - LSiM 706c
Sides - LSiM 703
Mits WD-82842 82" DLP 3DTV
Denon AVR-3313CI Receiver
Emotiva stealth DC-1
Emotiva XPA-2/Fronts XPA-3 Center-surrounds
Oppo 103
Loving the new Family!
Front wall is 206 inches
Side left wall is 155 inches
Back wall is 216 inches
Little side right wall is 90 and a half inches -
The Window it is actually a balcony.
Place your fronts about a foot wider than the sofas, and toe them in, so they point toward the center seating position. Go with front highs, you'll already have a pretty wide soundstage. Place the heights about 3 feet outside the mains, and as close to the ceiling as possible.
Thanks!
