Considering a pre amp (Adcom GFP-565)
muncybob
I was going to connect my old Pioneer cd player direct to my Parasound amp but have decided to go with a pre instead. Partly due to probably dusting off my turntable in the near future and also realizing that the variable output in the set up menu of the Pioneer is not what I thought it was. Looking for actual experiences with the Adcom GFP-565 preamp. The reviews I have read are good and I think it's probably is in my price range.
Yep, my name really is Bob.
Post edited by muncybob on
It is a nice pre with a great phono stage. No remote. I had one for about six months or so and went with. Parasound thwt had a remote. Comparable pres
No remote may be a deal breaker, bummer. I did have my eye also on a Parasound, certainly looks like a nice pre but was hoping to save some coin to buy a new cartridge.Yep, my name really is Bob.
Parasound HCA1500A(indoor sound) and HCA1000(outdoor sound), Dynaco PAS4, Denon DP1200 w/Shure V15 Type V and Jico SAS stylus, Marantz UD7007, Polk L600, Rythmik L12 sub. -
My 565 works wonderful & havent had any issues with it at all. I enjoy it on all items in my sig.Randy-Maine
2ch-RTA15tl crossover upgrade
by David WMG
Yamaha cr1000 cr2040
HT-Yamaha Parasound Acurus
Try and find an Anthem pre2L
If you get lucky maybe you can find a basic model for around $500. and do some upgrades along the way.
You will not find a better deal.
