home made TV/audio console table
Ducati Guy
This is My 1st attempt at woodworking/building a piece of furniture.
I went thru a couple of different designs, but finally decided on the simple design, WAF approved also.
A lot of trips to Loewe's, multiple wood cuts, sanding, staining, nails, & screws .... led to the final product.
Opinions please... (hopefully not too critical).
Bottom line, I like it very much, was a rewarding & learning curve project. I made the length of the table perfectly suited for a "dream-future" 80-85 inch 21:9 theatre wide Plasma TV, if they ever make them. The solid wood and big metal casters should support up to 300-lbs. It's nice to be able to roll the table out & have easier access to the back wires/plugs. Should be plenty of room to add a 7.2 A/V receiver also.
Post edited by Ducati Guy on
Looks very nice. I like the dark stain.2 ChannelTurntable - VPI Classic 2/Ortofon 2M BlueAmplification - Rogue Audio Cronus Magnum II, Parks Audio Budgie PhonoSpeakers - GoldenEar Triton 17.2 Home TheaterDenon AVR-X3300W; Rotel RMB-1066; Klipsch RP-280F's, Klipsch RP-450C, Polk FXi3's, Polk RC60i; Dual SVS PB 2000's; BenQ HT2050; Elite Screens 120"Man CaveTurntable - Pro-Ject 2.9 Wood/Grado GoldAmplification - Dared SL2000a, McCormack DNA 0.5 DeluxeCD: Cambridge AudioSpeakers - Wharfedale Linton 85th Anniversary; LSiM 703; SDA 2A
Thanks,
I actually used 3 different stains( red mahogany, dark walnut, walnut), to give it a 2-3 tone color, instead of just 1 color. -
I think you have really great wood.
It's 76 inches wide, 22 inches deep, & 19 inches tall. For size reference, it's a 60" plasma on top.
Ducati Guy wrote: »Thanks,
Stain question...do you mix the stains or put one at a time on, let it dry and do the next one?Anaheim Hills CA,
2 Channel: Rogue RP-5 / WireWorld Electra power cord / Marantz TT-15S1/ Ortofon - Quintet Black MC / Marantz NA8005 DAC / W4S mAmp's / Synology DS 216+ll-4TB / Polkaudio LSiM703 -
Very nice, looks nice and sturdy for whatever you want to put on it or in it.Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2
One stain only for each different piece.
The red mahogany for the top & bottom planks, the dark walnut for the supporting side structures. -
Your rack looks good, perfect fit for the recess it lives in. From the looks of extra material you have cut up, I'd say there are more projects in the works! Have fun.
Nice work!
thanks all,
I enjoyed wood working more than I thought I would.
Might make my own center speaker stand next. -
yes, the Ducati does need a wash ZLTFUL. Do you ride?
Ducati Guy wrote: »yes, the Ducati does need a wash ZLTFUL. Do you ride?
Yes he does... on the back of his wife's motorcyle
:biggrin:"....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963) -
Very nice: strong & functional! Manufactured furniture wouldn't typically be made out of thicket wood and wouldn't be able to support such a long span without deflecting/bending. It looks perfect for the space!Receiver: ONKYO TX-NR929 7.1 AVR 130wpc
Mains: 2x Polk RTA 8TL's
Center: Polk CS245i
Surrounds: 2x Klipsch RS-41ii (because they fit perfectly over the door and window)
Rear Surr: 2x Polk M4a '90
Subwoofer: Speakerlab DAS-SW dual-voice-coil 10" '88 30Hz-150Hz
Subwoofer Amp: ONKYO A-8019 AMP '85 100wpc
Display: Samsung 55" UNC55-8000 3D LED
Console: Xbox360
DVR: custom MythTV rig w/ 3 tuners OTA
Zone2: 2x Polk M5b '87 -
EndersShadow wrote: »Yes he does... on the back of his wife's motorcyle
hehe classic
