home made TV/audio console table
Ducati Guy
Ducati Guy Posts: 160
edited March 2014 in DIY, Mods & Tweaks
This is My 1st attempt at woodworking/building a piece of furniture.
I went thru a couple of different designs, but finally decided on the simple design, WAF approved also.
A lot of trips to Loewe's, multiple wood cuts, sanding, staining, nails, & screws .... led to the final product.
Opinions please... (hopefully not too critical).
Bottom line, I like it very much, was a rewarding & learning curve project. I made the length of the table perfectly suited for a "dream-future" 80-85 inch 21:9 theatre wide Plasma TV, if they ever make them. The solid wood and big metal casters should support up to 300-lbs. It's nice to be able to roll the table out & have easier access to the back wires/plugs. Should be plenty of room to add a 7.2 A/V receiver also.
003.JPG 208.2K
002.JPG 198.6K
001.JPG 210.9K
  • Ducati Guy
    edited March 2014
  • Ducati Guy
    edited March 2014
  • Ducati Guy
    edited March 2014
  • hochpt21
    hochpt21 Posts: 5,423
    edited March 2014
    Looks very nice. I like the dark stain.
  • Ducati Guy
    edited March 2014
    Thanks,
    I actually used 3 different stains( red mahogany, dark walnut, walnut), to give it a 2-3 tone color, instead of just 1 color.
  • polkfarmboy
    polkfarmboy Posts: 5,703
    edited March 2014
    I think you have really great wood.
  • Ducati Guy
    edited March 2014
    It's 76 inches wide, 22 inches deep, & 19 inches tall. For size reference, it's a 60" plasma on top.
  • gce
    gce Posts: 2,158
    edited March 2014
    Ducati Guy wrote: »
    Thanks,
    Stain question...do you mix the stains or put one at a time on, let it dry and do the next one?
    Anaheim Hills CA,
    HT 5.1: Denon X3900H/ BDP-Denon DBT1713UD / Polkaudio LSiM703 / W4S mAmp's / Polkaudio LSiM706c / Polkaudio LSiM702F/X's / SVS SB2000 Pro / Panasonic TC P55VT30
  • cfrizz
    cfrizz Posts: 13,415
    edited March 2014
    Very nice, looks nice and sturdy for whatever you want to put on it or in it.
  • Ducati Guy
    edited March 2014
    One stain only for each different piece.
    The red mahogany for the top & bottom planks, the dark walnut for the supporting side structures.
  • Mike Reeter
    Mike Reeter Posts: 4,315
    edited March 2014
    Your rack looks good, perfect fit for the recess it lives in. From the looks of extra material you have cut up, I'd say there are more projects in the works! Have fun.
  • 4xoddic
    4xoddic Posts: 372
    edited March 2014
    Nice work!
  • Ducati Guy
    edited March 2014
    thanks all,
    I enjoyed wood working more than I thought I would.
    Might make my own center speaker stand next.
  • Ducati Guy
    edited March 2014
    yes, the Ducati does need a wash ZLTFUL. Do you ride?
    EndersShadow Posts: 17,765
    edited March 2014
    Ducati Guy wrote: »
    Yes he does... on the back of his wife's motorcyle :wink:....
    :biggrin:
  • Zentish
    Zentish Posts: 127
    edited March 2014
    Very nice: strong & functional! Manufactured furniture wouldn't typically be made out of thicket wood and wouldn't be able to support such a long span without deflecting/bending. It looks perfect for the space!
    Receiver: ONKYO TX-NR929 7.1 AVR 130wpc
    Mains: 2x Polk RTA 8TL's
    Center: Polk CS245i
    Surrounds: 2x Klipsch RS-41ii (because they fit perfectly over the door and window)
    Rear Surr: 2x Polk M4a '90
    Subwoofer: Speakerlab DAS-SW dual-voice-coil 10" '88 30Hz-150Hz
    Subwoofer Amp: ONKYO A-8019 AMP '85 100wpc
    Display: Samsung 55" UNC55-8000 3D LED
    Console: Xbox360
    DVR: custom MythTV rig w/ 3 tuners OTA
    Zone2: 2x Polk M5b '87
    pitdogg2 Posts: 27,917
    edited March 2014
    hehe classic
