Emotiva and LSi´s setup
inbox
inbox Posts: 21
edited March 2014 in Speakers
i have LSi9/LSi7 and LSiC speakers system with a AV Sony DA2400ES (85W, 4 ohm). The true is i don´t understand why some people recommend me to buy a amp like a Emotiva UPA-700 (100W, 4 ohm) (the emotiva UPA 500 seems to be unavailable...)
would it be a right choose for listing music and movies? 25 watts of difference, is it enough? do I notary difference?
thanks in advanced
Sony DA2400ES
LSi9 - LSiC -LSi7
SW 660wi 12´´
Post edited by inbox on
  • inbox
    inbox Posts: 21
    edited March 2014
    then, these specs in multichannel mode are theoretical?
    Sony DA2400ES
    (4 ohm 1 kHz, THD 0,7%)
    FRONT: 100 W + 100 W
    CENTER: 100 W
    SURROUND: 100W + 100W
    SUR BACK2: 100W + 100W
    thank you very much
    Sony DA2400ES
    LSi9 - LSiC -LSi7
    SW 660wi 12´´
    tonyb Posts: 33,069
    edited March 2014
    inbox wrote: »
    Sony DA2400ES
    CENTER: 100 W
    thank you very much
    It's not so much what those specs say....as what they DON'T say. Like all channels driven. Driving 4 ohm speakers with an AVR is pretty much risky business. 9 out of 10 avr's that claim they can drive 4 ohm loads, in reality, is simply engaging a safety to keep the avr from over heating by limiting current. Which 4 ohm speakers thrive on more current. Follow ?
  • eclypse
    eclypse Posts: 595
    edited March 2014
    U jave 30 days to try the amp out.and return it if i think it aint doing it for ya.. might be just enoigh but more power equalls more head room for dynamics. With that said 200 watts and up is what id be looking at
    No idea why people arent saying go with a xpa-5. If u can swing it grab a xpa-2 and use that just for the fronts. Though the xpa-5 is prob all u need as i can just run a.set.of rear.channel speakers off ur current avr as they wont use much power as rears seldom do.
    Lots of people say no home theater should be wothout a xpa-5!
    Full 5 channel set of Polk Audio
    Fronts - LSiM 705
    Center - LSiM 706c
    Sides - LSiM 703
    Mits WD-82842 82" DLP 3DTV
    Denon AVR-3313CI Receiver
    Emotiva stealth DC-1
    Emotiva XPA-2/Fronts XPA-3 Center-surrounds
    Oppo 103
    Loving the new Family! :)
  • inbox
    inbox Posts: 21
    edited March 2014
    Will there be much difference between UPA-700 and XPA-5 for my LSi setup?
    (and thanks for your answers)
    Sony DA2400ES
    LSi9 - LSiC -LSi7
    SW 660wi 12´´
  • eclypse
    eclypse Posts: 595
    edited March 2014
    It would be best to head over to emotivas forums and search for ur answers.. im sure if u ask u would get a response as ive seen quite a few people using polk lsi speakers with there amps. http://emotivalounge.proboards.com
    Fronts - LSiM 705
    Center - LSiM 706c
    Sides - LSiM 703
    Oppo 103
  • inbox
    inbox Posts: 21
    edited March 2014
    eclypse wrote: »
    thanks a lot! i will
    Sony DA2400ES
    LSi9 - LSiC -LSi7
    SW 660wi 12´´
