Emotiva and LSi´s setup
i have LSi9/LSi7 and LSiC speakers system with a AV Sony DA2400ES (85W, 4 ohm). The true is i don´t understand why some people recommend me to buy a amp like a Emotiva UPA-700 (100W, 4 ohm) (the emotiva UPA 500 seems to be unavailable...)
would it be a right choose for listing music and movies? 25 watts of difference, is it enough? do I notary difference?
thanks in advanced
thanks in advanced
Sony DA2400ES
LSi9 - LSiC -LSi7
SW 660wi 12´´
LSi9 - LSiC -LSi7
SW 660wi 12´´
Post edited by inbox on
then, these specs in multichannel mode are theoretical?
Sony DA2400ES
(4 ohm 1 kHz, THD 0,7%)
FRONT: 100 W + 100 W
CENTER: 100 W
SURROUND: 100W + 100W
SUR BACK2: 100W + 100W
thank you very muchSony DA2400ES
LSi9 - LSiC -LSi7
SW 660wi 12´´ -
Sony DA2400ES
CENTER: 100 W
thank you very much
It's not so much what those specs say....as what they DON'T say. Like all channels driven. Driving 4 ohm speakers with an AVR is pretty much risky business. 9 out of 10 avr's that claim they can drive 4 ohm loads, in reality, is simply engaging a safety to keep the avr from over heating by limiting current. Which 4 ohm speakers thrive on more current. Follow ?HT SYSTEM-
lsi 9's -
U jave 30 days to try the amp out.and return it if i think it aint doing it for ya.. might be just enoigh but more power equalls more head room for dynamics. With that said 200 watts and up is what id be looking at
No idea why people arent saying go with a xpa-5. If u can swing it grab a xpa-2 and use that just for the fronts. Though the xpa-5 is prob all u need as i can just run a.set.of rear.channel speakers off ur current avr as they wont use much power as rears seldom do.
Lots of people say no home theater should be wothout a xpa-5!Full 5 channel set of Polk Audio
Fronts - LSiM 705
Center - LSiM 706c
Sides - LSiM 703
Mits WD-82842 82" DLP 3DTV
Denon AVR-3313CI Receiver
Emotiva stealth DC-1
Emotiva XPA-2/Fronts XPA-3 Center-surrounds
Oppo 103
Loving the new Family!
Will there be much difference between UPA-700 and XPA-5 for my LSi setup?
(and thanks for your answers)Sony DA2400ES
LSi9 - LSiC -LSi7
SW 660wi 12´´ -
It would be best to head over to emotivas forums and search for ur answers.. im sure if u ask u would get a response as ive seen quite a few people using polk lsi speakers with there amps. http://emotivalounge.proboards.comFull 5 channel set of Polk Audio
Fronts - LSiM 705
Center - LSiM 706c
Sides - LSiM 703
Oppo 103
thanks a lot! i willSony DA2400ES
LSi9 - LSiC -LSi7
SW 660wi 12´´
