A guess on what amp this is?
zingo
zingo Posts: 11,258
edited March 2014 in DIY, Mods & Tweaks
It's obviously a DIY and looks Rawson to me, but the single output device per channel makes me think chip amp?
$_57.JPG 352.4K
Post edited by zingo on
  • zingo
    zingo Posts: 11,258
    edited March 2014
  • zingo
    zingo Posts: 11,258
    edited March 2014
  • zingo
    zingo Posts: 11,258
    edited March 2014
    pitdogg2 Posts: 27,563
    edited March 2014
    Scored a nice case anyhow:)
  • zingo
    zingo Posts: 11,258
    edited March 2014
    Not mine yet... :redface:
    It's a little hard to see details from the pictures, but it is a nice chassis with components none-the-less.
    edited March 2014
  • zingo
    zingo Posts: 11,258
    edited March 2014
    No blood, no foul. :lol:
  • FTGV
    FTGV Posts: 3,650
    edited March 2014
    Gain clone chip amp,possibly using an LM3886 or LM3875.
  • skrol
    skrol Posts: 3,480
    edited March 2014
    Did you mean fowl? I say..I say..someone stole your innards son.
    Give us the run down on this. It looks interesting.
    Stan
    Main 2ch:
    HT:
    Other stuff:
  • zingo
    zingo Posts: 11,258
    edited March 2014
    skrol wrote: »
    Foul: adverb
    1.
    unfairly; contrary to the rules.
  • zingo
    zingo Posts: 11,258
    edited March 2014
    FTGV wrote: »
    Thanks Fred! Gain clone was my thought based on the looks, but I've never built one, so I thought I'd ask all those who are smarter than me.
    skrol wrote: »
    I just purchased it and will have to wait to get it in the mail. No idea about the sound quality, but the build looks decent, and I can always resell it for what I paid.
  • skrol
    skrol Posts: 3,480
    edited March 2014
    zingo wrote: »
    Foul: adverb
    1.
    That is the last time I try a Foghorn Leghorn impersonation.
    Stan
    Main 2ch:
    HT:
    Other stuff:
  • zingo
    zingo Posts: 11,258
    edited March 2014
    Your Foghorn Leghorn impression is almost as bad as John Travolta's ability to pronounce names... :P
  • Face
    Face Posts: 14,340
    edited March 2014
    If built correctly, expect a clean sound without a whole lot of umph.
  • zingo
    zingo Posts: 11,258
    edited March 2014
    What do you mean by lack of umph? Like 50wpc not much umph? It looks like it has a decent power supply; and non-smps to boot!
  • Face
    Face Posts: 14,340
    edited March 2014
    I have a very similar build(non smps too) and it sounded thin in comparison to my Wyred amps...and even the little Pass F5 I had. Fine for the high or mid section of an active setup, or small desktop though.
  • zingo
    zingo Posts: 11,258
    edited March 2014
    Thanks for the thoughts. Since these chip amps are class A/B, I'll be interested to compare it against similar powered Tripath.
  • zingo
    zingo Posts: 11,258
    edited March 2014
    Well I played "Lets Make a Deal" with the seller since he was semi-local, and I have the amp at my house tonight. :D
    The output devices are one LM3886T per channel, fed by 55VDC, and with an offset of 35mv. Seems well built and we'll see how it sounds!
  • FTGV
    FTGV Posts: 3,650
    edited March 2014
    I assume 55 vdc total not+ - 55vdc?Otherwise your exceeding a safe value.It does appear to have a decent supply with plenty of filter capacitance and hefty toroid.Many have used these chips with a mere 2000uf or so of filter capacitance.Why they under sized them makes no engineering sense but...
  • zingo
    zingo Posts: 11,258
    edited March 2014
    Correct Fred, 55VDC + to -. The transformer is rated at 340VA, and it's a snubberized PS with 20000uF of capacitance.
  • FTGV
    FTGV Posts: 3,650
    edited March 2014
    340va.Then you have plenty of transformer and heat sink area to add another pair of modules and make it a 4ch.
  • zingo
    zingo Posts: 11,258
    edited March 2014
    But I only need two channels... Got another idea for single input 4 ohm speakers? :P
  • FTGV
    FTGV Posts: 3,650
    edited March 2014
    Sure hook 4 modules in 2 sets of parallel(not bridged).That will give you increased current to drive lower impedances.
  • zingo
    zingo Posts: 11,258
    edited March 2014
    That does look like a good option; even Jeff Rowland has an amp based on parallel LM3886s. The amp's been on for an hour and it's not even warm so I'm going to give it a listen and see how this thing sounds.
    Thanks Fred!
  • zingo
    zingo Posts: 11,258
    edited March 2014
    After having the amp on for two hours last night, I gave it a listen with a few different albums and was impressed. The LM3886 amplification was clean, detailed, natural, and seemed to have sufficient power. However, I was testing it on a pair of monitors with a subwoofer running bass duty, so that may help the amp keep its composure longer. I'll test it this weekend specifically against my Tripath amp to see how the chips compare, but I do like that the LM3886 has no tweeter hiss associated with class-D.
    The amp and circuit was very well built, with star-grounding (and chassis grounding), solid electrical connections, high quality components including Cardas connectors and a Plintron transformer, and proper voltages at all test points with no hum or buzz.
