What kind of Turntables are you running??? Pics!
MJJCREW
^^^^ nice turntable^^^^I just pick this Audio Technica AT PL120 up for a great price & it does very well-so far
Randy-Maine
2ch-RTA15tl crossover upgrade
by David WMG
Yamaha cr1000 cr2040
HT-Yamaha Parasound Acurus
Kenwood KD-770D that I picked up at a used record for $75 about 7 years ago.
Quote: from the Vinylengine
Description
The precision engineered KD-770D features the Kenwood ultra-rigid DL motor and high stability HS tonearm for outstanding music reproduction accuracy.
Specifications
Drive system: direct drive
Motor: Quartz PLL coreless and slotless DC servo motor
Platter: 33cm aluminium alloy die-cast
Speeds: 33.33 and 45rpm
Wow and flutter: less than 0.02% WRMS
Rumble: better than -80dB
Tonearm: straight pipe arm
Effective length: 245mm
Overhang: 15mm
Stylus pressure range: 0 to 3g
Usable cartridge range: 2 to 12g
Dimensions: 490 x 162 x 410mm
Weight: 11.7kg
Because I am The Pumpkinking
Daily driver is a dump-find Technics SL-Q2 to which I fitted a Denon DL-103 low output moving coil cartridge (it's the only arm in the house any where near heavy enough for the very low compliance DL-103).
dubbin081212 by mhardy6647, on Flickr
The two primary on-deck tts are a bang & olufsen TX-2 with b&o MMC-4 "micro moving cross" (moving iron) cartridge and a Marantz TT-15S1 (essentially a tarted up Clearaudio Emotion) with the ebony armwand version of the CA "Satisfy" arm and a (thoroughly mediocre, by the way) CA wood body moving magnet cartridge (I think the model is "Virtuoso", but I don't remember fo' sho').
TX-2 by mhardy6647, on Flickr
TT15S12 by mhardy6647, on Flickr
There are others that get lugged out from time to time...
holidaydubbing121209 by mhardy6647, on Flickr -
Here is my VPI HW-19 MKIII (from the mid 90's) that purchased about a year after the Kenwood
I swapped out the Rega RB-250 arm for an SME and upgraded to a heavier platter.
A friend made me the sandbox from MDF and it's covered with African bubinga veneer.
pumpkinman wrote: »
oooh :-) -
Marantz 6300 w/EmpireRandy-Maine
by David WMG
Music Hall mmf 5.1
Musical Surroundings Phonomena II
My New Year's resolution is 3840 × 2160
Garage | Polk Monitor 5B's
Closet Yamaha M80 | 2 Polk MP3K subs| Yaqin MC100B with Shuguang Treasures KT 88's & CV181Z's | Tesla E83CC's | Marantz 2252B | Marantz 2385 |Polk SDA SRS 2.3 | LSiM 705's | -
Pro-Ject 2.9 wood with a pear-wood plinth. I currently have a Grado gold cart on it.2 ChannelTurntable - VPI Classic 2/Ortofon 2M BlueAmplification - Rogue Audio Cronus Magnum II, Parks Audio Budgie PhonoSpeakers - GoldenEar Triton 17.2 Home TheaterDenon AVR-X3300W; Rotel RMB-1066; Klipsch RP-280F's, Klipsch RP-450C, Polk FXi3's, Polk RC60i; Dual SVS PB 2000's; BenQ HT2050; Elite Screens 120"Man CaveTurntable - Pro-Ject 2.9 Wood/Grado GoldAmplification - Dared SL2000a, McCormack DNA 0.5 DeluxeCD: Cambridge AudioSpeakers - Wharfedale Linton 85th Anniversary; LSiM 703; SDA 2A
Sony PS-LX410 with a Grado black.
2 ChannelTurntable - VPI Classic 2/Ortofon 2M BlueAmplification - Rogue Audio Cronus Magnum II, Parks Audio Budgie PhonoSpeakers - GoldenEar Triton 17.2 Home TheaterDenon AVR-X3300W; Rotel RMB-1066; Klipsch RP-280F's, Klipsch RP-450C, Polk FXi3's, Polk RC60i; Dual SVS PB 2000's; BenQ HT2050; Elite Screens 120"Man CaveTurntable - Pro-Ject 2.9 Wood/Grado GoldAmplification - Dared SL2000a, McCormack DNA 0.5 DeluxeCD: Cambridge AudioSpeakers - Wharfedale Linton 85th Anniversary; LSiM 703; SDA 2A -
1971 Pioneer PL a35d completely stock with remote controlRandy-Maine
by David WMG
Nice tables guys. I'm out visiting father right now but when I get
home I post my last table.
Damn those are some beautiful tables!!! Something to shoot for!!
i use to own one of those & it played very wellAs noted in a hookup thread I have the Audio Technica AT-LP60-USB, It's still available in the open market. Works quite well for what it is and still outputs in MM, not bad for something designed to "rip" LPs to PC. Pics ? Google...I'm feelin a touch lazy LOL
Randy-Maine
by David WMG
Bluenote Bellavista with Signature 5 arm and Dynavector 20-Xh MC cartridge.
Phono stage is newly factory freshened PS Audio GCPH. -
Hello,
This is a Maplenoll Ariedne Signature turntable with Shelter 901 moving coil cartridge stepped up by a Bent Audio transformers and feeding a Tom Tutay designed phono preamp. I use a VPI turntable power source for motor control and conditioning.
Cheers, Ken -
Technics SL-1300 MK2
A diy heavy plinth/trimmed top plate heavy platter idler drive L75 Lenco. Advanced Analog MG-1 linear tracking air bearing arm. Two arms, one with a Karat 17D3, the other with an aluminum body Denon 103R.
Got tired of the all black....wrapped plinth with maple.
Currently amplifying the LOMC's with a diy Cinemag head amp through the MM stage of my Krell pre amp.
In the retro system....a vertical linear tracking Mitsubishi LT-5V.
It works and sounds great!
<iframe width="420" height="315" src="//www.youtube.com/embed/T8OjlcJjSEE" frameborder="0" allowfullscreen></iframe>Salk SoundScape 8's * Audio Research Reference 3 * Bottlehead Eros Phono * Park's Audio Budgie SUT * Krell KSA-250 * Harmonic Technology Pro 9+ * Signature Series Sonore Music Server w/Deux PS * Roon * Gustard R26 DAC / Singxer SU-6 DDC * Heavy Plinth Lenco L75 Idler Drive * AA MG-1 Linear Air Bearing Arm * AT33PTG/II & Denon 103R * Richard Gray 600S * NHT B-12d subs * GIK Acoustic Treatments * Sennheiser HD650 * -
Mike Reeter wrote: »
I have a Rogue Stealth also but it's not a Magnum. Was it upgraded from a Steath or was it a Magnum from the start.
Rogue has upgrades for most of it's products.
Lots of fine looking tables here.SCompRacer i like how that came out. Very nice sirRandy-Maine
by David WMG
pumpkinman wrote: »I have a Rogue Stealth also but it's not a Magnum. Was it upgraded from a Steath or was it a Magnum from the start.
I bought the Stealth directly from Rogue, it was a standard unit that had been sent out for a review and then returned. I had Rogue upgrade the unit to a Magnum version.
It is the fourth piece of Rogue gear I've had over the years, I would like to upgrade to the Ares Phono Pre one day. I like their products and their "sound". -
Just the different tables and set ups on all these is so cool to me.....These tables from the vintage stock to the high dollar new are all cool in their own perspective ways...Being from Indiana I am usually getting edgy about February, March wanting to ride my cycles...but since getting started in Audio this winter is a little more tolerable!!
Love it!! -
Micro Seiki DD-35
Sorry for the low quality pic. This was when I first got it home and was testing it.
Expert Moron Extraordinaire
No picture, but.
Thorens TD-125, Rabco Linear Tonearm, Shure SME tone arm. Various cartridges. Adcom crosscoil linetrace, Shure V-15 Type III,
A bunch of cheapo ones from going out of business sales. -
I'm running a Sony PS-X75 Biotracer with TTWeights copper and carbon fiber upper mat, magnesium lower mat, copper center weight, and outer ring. I use either a Cinemag, Byer Dynamic, or Sony step up transformer in conjunction with a level 2 modded Jolida JD-9 depending on the cartridge. Cartridges include Soundsmith retipped Shelter 501 MK2, ZU-Denon DL103R, ebony bodied DL103R, metal bodied DL103S, black & white ebony bodied DL103, Denon DL303, Audio Technica AT33PTG, Grado Reference Sonata, Soundsmith retipped Dynavector DV20XH, and Technics EPC205 MK4.
Umm, I suspect I speak for many here when I say, "aww, c'mon and post a few!" ;-)No picture, but.
Thorens TD-125... -
Man, you fella's make me feel bad about my TT's lol.....
I have 2 right now. One was from Travis (TNHNDYMAN) and its a fully auto TT for if I feel lazy.... its been acting weird so I took it out of the mix for now...
The other one I use a bit more is the Pro-Ject Debut III I got off a different Travis (trav0821)
MJJCREW, if I ever have a Polk gathering, your welcome to come. Hoping later this summer after I get some stuff done at the new house to hold something along those lines..."....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963) -
Soon to replace my recently purchased table should be in my possession by the end of the week..
I love the look of this TT and it comes with a Ortofon Cadenza Red..
It's a Pro-Ject Extension 10
