Pioneer SC-75 & Oppo 103D hook up
ninerbj
I will be hooking these two together this weekend and wondered if I should let the Pioneer do the decoding or the Oppo? Any thoughts on this would be appreciated.
Thanks!
BJ
Thanks!
BJ
"she had the body of Venus, with arms."
Post edited by ninerbj on
Usually you should have the player do the decoding... For some reason, a lot of receivers have issues decoding some movies and the fix is to have the players do the decoding....
^^^Agreed let the Oppo do it's job2-channel: Modwright KWI-200 Integrated, Dynaudio C1-II Signatures
I would try it both ways and see which you like better. From some reviews I've seen, the Darbee on the Oppo doesn't work so well for Blu-ray but does for standard dvd discs. Pioneer is no slouch either when processing video.HT SYSTEM-
lsi 9's -
I can't speak on the Oppo but both the Pioneer units I had worked great decoding the signal from my PS3. Plus I like being able to see the format on the display.2.2 Office Setup | LG 29UB55 21:9 UltraWide | HP Probook 630 G8 | Dell Latitude | Cabasse Stream Amp 100 | Boston Acoustics VS 240 | AUDIORAX Desk Stands | Sub 1 - Mirage Omni S8 | Sub 2 - Mirage Omni S8
