Pioneer SC-75 & Oppo 103D hook up
I will be hooking these two together this weekend and wondered if I should let the Pioneer do the decoding or the Oppo? Any thoughts on this would be appreciated.
Thanks!
BJ
"she had the body of Venus, with arms."
  • jon s
    edited February 2014
    Usually you should have the player do the decoding... For some reason, a lot of receivers have issues decoding some movies and the fix is to have the players do the decoding....
    ^^^Agreed let the Oppo do it's job
    edited March 2014
    I would try it both ways and see which you like better. From some reviews I've seen, the Darbee on the Oppo doesn't work so well for Blu-ray but does for standard dvd discs. Pioneer is no slouch either when processing video.
  • WLDock
    edited March 2014
    I can't speak on the Oppo but both the Pioneer units I had worked great decoding the signal from my PS3. Plus I like being able to see the format on the display.
    5.2 A/V Setup | OLED TV - Sony Bravia XR A80J 77" | Source - Fire TV 4K Max, Wiim Pro | AVR - Anthem MRX 520 | Integrated - Musical Fidelity A5 | Speakers: Main - Boston Acoustics VS 336 | Center - Boston Acoustics VS 325c | Rear - Boston Acoustics VR-MX | Sub 1 - Boston Acoustics VPS 210 | Sub 2 - HSU VTF-2 mk3
