Pioneer SC-75 & Oppo 103D hook up
ninerbj
ninerbj Posts: 870
I will be hooking these two together this weekend and wondered if I should let the Pioneer do the decoding or the Oppo? Any thoughts on this would be appreciated.
Thanks!
BJ
"she had the body of Venus, with arms."
Post edited by ninerbj on
  • jon s
    jon s Posts: 905
    edited February 2014
    Usually you should have the player do the decoding... For some reason, a lot of receivers have issues decoding some movies and the fix is to have the players do the decoding....
    txcoastal1 Posts: 13,514
    ^^^Agreed let the Oppo do it's job
    edited March 2014
    I would try it both ways and see which you like better. From some reviews I've seen, the Darbee on the Oppo doesn't work so well for Blu-ray but does for standard dvd discs. Pioneer is no slouch either when processing video.
  • WLDock
    WLDock Posts: 3,073
    edited March 2014
    I can't speak on the Oppo but both the Pioneer units I had worked great decoding the signal from my PS3. Plus I like being able to see the format on the display.
