finally my new turn table
leftwinger57
leftwinger57 Posts: 2,917
edited February 2014 in Electronics
After getting rejected from an E-Bay auction I went w/ Statement Audio to get the tt. It's a JVC-QL-A200 direct drive w/ semi auto action. This tt is way better than my older Denon DP-11 F which never shut off. Here you when you lift the arm the pivot action starts the motor and when it's at the end it does return and shut off. The cart is better than the Grado Black I just bought but Tom said he played his special records on it and the cart is way better than the standard Black model. Packing was superb he even added the travel bolts that most shippers do not even know about. It came clean and shined up w/ instructions on how to do the balancing. It works great,I couldn't be happier and now I'm playing my LPs that I bought after my Denon died and never heard before is a pleasure.
http://s42.photobucket.com/user/leftwinger57leftwinger/media/DSCN03771_zpsfdea2e79.jpg.html
  • hochpt21
    hochpt21 Posts: 5,423
    Congrats Lew!
    Enjoy the spinning.
  • Jhayman
    Jhayman Posts: 1,548
    Congrats on the new table, enjoy :biggrin:
  • leftwinger57
    Thanks guys. After having a device for a while ,getting used to it how ever lame it was it worked. Now w/ this one it works and sounds better and I feel better because I don't have to look at the empty shelf anymore after tossing the Denon.
  • pglbook
    pglbook Posts: 2,258
    Congrats on the new turntable. Enjoy spinning some vinyl!
  • leftwinger57
    I forgot to mention when I got the tt the a.c. cord and RCAs were long enough but there was no ground wire. This is the 1st tt that I have seen w/o a ground wire waiting to be screwed onto the chassi of the pre. Someone said the ground is in the outer part of the rca ring on the white side. I have no idea if that's right or not but it does work just fine. I think the cartridge is a Grado FT+1.
    SCompRacer Posts: 9,111
    Congrats on your new table! True, sometimes grounding is done through neg of RCA. A pic of that from a Thorens manual. Some old cartridges were supplied with a removable ground strap that connected the head shell to one channels ground lug on the cartridge.
  • boston1450
    boston1450 Posts: 7,758
    Congratulations LW on your new tt. My Audio Technica 120 doesnt have a ground wire either. Enjoy your new addition
    Randy-Maine
    2ch-RTA15tl crossover upgrade
    by David WMG
    Yamaha cr1000 cr2040
    HT-Yamaha Parasound Acurus
    MIT BJC Cs1000p Polk Rotation
  • pumpkinman
    pumpkinman Posts: 10,229
    That's great Leftwinger57 we need more guys spinning vinyl again.
    Best of luck with your new purchase
    P-man
    Because I am The Pumpkinking
  • PolkieMan
    PolkieMan Posts: 2,446
    Very nice TT !
