Rear speakers
trelytarms
trelytarms Posts: 4
edited February 2014 in Speakers
I have the monitor 75t, 25c center, psw108 sub and a sony strda1800es 7.2 receiver. What speakrs should i be using for the side and back? 4 monitor 45b?
Post edited by trelytarms on
    Welcome to Club Polk!
    Any of that series bookshelves will work. Frankly I'm not sure what model the 45bs are; are they the large bookshelf or the entry level tower. You could use either. All you need to do is match the drivers in your series which any member of the series will do.
    You would be better off with a bigger better sub than the 108 because it won't add much to what the towers can already do!
    cnh
  • trelytarms
    trelytarms Posts: 4
    Thanks to both of you. New to the home theatre and thought the 45b bookshelf were to big for the rear surround speakers.
