Speakers
mbarber
I have connected my polk front speakers through the sub as
opposed to using the pre-out jack. Is this the best set-up?Also
it says so select no sub on my receiver setup?Any feed back would be great.
Yamaha HTR-5750 6.1 Receiver
Polk PSW303 sub
Polk RM 2350 Satellites
Polk RM 2650 Center Channel
Polk PSW303 sub
Post edited by mbarber on
Would get more better reponse if you list your gear.....Life without music would♭
Many think that is the best way to hook up your system.....on your receiver set mains to large and sub to off or no.
If you like it, than that's the way to do it. No?
I set mine up this way (as "Polk" has said) and the sound is good!SYSTEM
HDTV ..........Sony KP-57WV600
CD / DVD......Sony DVP-C675D
AVR ............Denon 2801
MAINS .........Polk RTi8
CENTER .......Polk CSi5
Surrounds ....Polk FXi3
Sub ............Polk PSW-250
Cables.........Zebra Cables -
I have to disagree with the "Polk way." I used to have mine setup that way til Dr. Spec enlightened me. With just your fronts hooked up, pop in your favorite CD and crank it up a little. Now, on your receiver, switch back and forth between large and small. Which way does the midrange sound better to you? Decide for yourself.
Regards,
PolkThug
