RX-V1800 HDMI out port damaged
hardwaterhunter
New to this (forums and website) so be patient. I have a RX-V1800 with a damaged HDMI out port. Can it be repaired and/or is it worth it? The damage is visible, although it took about an hour of troubleshooting cursing and double checking with every single HDMI cord in the house before I turned up the lights grabbed a flashlight and looked in the port. The 2nd pin from the top on the right is gone and the third pin on the left is clearly "smashed" to the back of the port. So far no guilty parties have admitted to touching any of my valuable components but every time I ask the dog what happened he looks right at the cat.....I think he is on to something. Please let me have it, right or wrong. After spending some time perusing other posts. I am glad to call this forum- my first.
My Room
monitor65T CS2 Rm8
SA-W2500
BDP-S5100
DW339DLP M120HSR-PRO SERIES
monitor65T CS2 Rm8
SA-W2500
BDP-S5100
Post edited by hardwaterhunter on
Sweet I am the first one to reply to my own post. I forgot to add that I have or was given 2 monitor 65T's and a CS2. I know there is much better but that is what I have. Thanks for reading.My Room
monitor65T CS2 Rm8
SA-W2500
BDP-S5100
DW339DLP M120HSR-PRO SERIES -
I don't know if its worth getting repaired or not, but the hdmi boards are usually pretty pricey and that is probably no longer under warranty. If you have an authorized yammie dealer nearby it might be worth getting checked out. Otherwise I would sell it on ebay as for parts or not working (but specify in the description that everything else still works) and put the 75-100 you will get towards a new (or used) receiver. Sorry that happened and that I don't have a better answer. That is a GREAT receiver so that really sucks.
but nonetheless welcome to CP!Living Room 2.2: Usher BE-718 "tiny dancers"; Dual DIY Dayton audio RSS210HF-4 Subs with Dayton SPA-250 amps; Arcam SA30; Musical Fidelity A308; Sony UBP-x1000es
Deep down I knew the answer but I needed someone else to tell me. OK I am going to put it up for sale and see what happens. Man I am going to miss it. Now that that is over what are some good options for me? Let's start with what I have no laughing now! I am here so you guys can help me get the best out of my current system and/or upgrade. OK in the room I use most for all media I have-
Monitor 65T pair
CS2
RM8 pair
SA-W2500
BDP-S5100
DW339 DLP
M120HSR Pro Series
XBOX360
And last but not least the RX-V1800. I do have in a box I just dug out of the storage room a BDP-S5100 but I can't imagine that thing could run my current speakers and there is no way I am using the ones it came with. Any thoughts on a AV receiver for the well rounded movie/music room are greatly appreciated. Oh and the dog told me again it was the cat...Man I am going to miss that receiver.My Room
monitor65T CS2 Rm8
SA-W2500
BDP-S5100
I'd get rid of the cat, but the again I'm a dog person.Home Theater
Two Channel
Oppo 105D BAT VK-500 w/BatPack SDA SRS 2.3 Dreadnought Squeezebox Touch Apple TV -
Ha that's what I told the wife......man its cold in the garage tonight.My Room
monitor65T CS2 Rm8
SA-W2500
BDP-S5100
I have seen oppo on many a posters signatures but have not looked it up until now. Any specific model you recommend? Again I am new to this so everyone please be patient.My Room
monitor65T CS2 Rm8
SA-W2500
BDP-S5100
What about an HDMI splitter? Do they work? Ok that is a dumb question I am sure they do what they are supposed to do but does using on degrade the sound and picture quality? Does anyone have an opinion or experience with HDMI splitters? Please keep in mind the distance from brp to projector is 12' 3" non negotiable.My Room
monitor65T CS2 Rm8
SA-W2500
BDP-S5100
Thank you so much DSkip you have single handedly saved my receiver. I am going to get the BYTECC HMSP102 $26.99 over at newegg. Unless someone has some better opinions, options or ideas but I think a splitter is the way to go for me but then again an oppo would be a great way to begin my upgrade one or two peices at a time.My Room
monitor65T CS2 Rm8
SA-W2500
BDP-S5100
What type of display do you have the RX-V1800 connected to?
If it has component connections, you could go that route - nothing wrong with that.
Nice unit - I have one too.
