What makes an audio rack an audio rack?
Pycroft
Pycroft Posts: 1,961
edited February 2014 in 2 Channel Audio
Hi all -
There's a reason for this question -
A lot of racks say they reduce vibration, and do other things that make the sound improve. Here's the situation -
I work at a high school that has a great woodshop teacher. Each year, students of his take on BIG projects (In the past, those that stand out are grandfather clocks, canoe's, etc.). I would love to see if a student of his can work on building a rack. The question is - what makes it an audio rack? I look at something like this: http://app.audiogon.com/listings/stands-timbernation-cherry-wood-rack-with-satin-lacquer-finish-2014-02-06-accessories-16686 - and it just looks like a real nice piece of furniture to put audio equipment in. Is there some design, or something else that makes a typical 'shelf' turn into audio furniture?
Is there desired woods for certain effects? Does it matter if it is full wood, or something hollowed out to allow to be filled (I see people putting sand and other junk in their stands). Would love to hear from those who have made items like this before.
Thanks!
James
2 Channel/HT:
Sony SS-M9 P's (ES version)
Sony SS-M1CN Center Channel
Polk RT800 Surround Speakers
Odyssey Stratos Dual Mono Amplifiers
TAD 150 Signature Tube Preamp
Harman Kardon HK354
Sony SACD Player
Post edited by Pycroft on
    mhardy6647 Posts: 35,194
    ...for me, if an audio component fits on it, it's an audio rack (or at least it can be).
  • Pycroft
    Dd you plan them to lessen vibration, or did you just plan them to fit your components and look nice? Is there some schematics or scaled drawings you made with some design. I agree with mhardy, if it fits my stuff, putmitnthere. I'm trying to figure if there's something more than meets the eye when it comes to audio racks.
    James
    2 Channel/HT:
    Harman Kardon HK354
    Sony SACD Player
    EndersShadow Posts: 17,718
    Pycroft wrote: »
    James
    Eh forget the vibration stuff, have them make a rack thats flexible with shelf placement so you can modify it as your gear gets bigger, smaller, etc with more or less shelves.
    Then just factor in some cookies or vibration dampners on your own.
    The one thing I would suggest is if this is meant to hold a TT to have them build a little sandbox (which you fill with sand) and then float a board on top of it for vibration isolation for your TT.
  • BlueFox
    BlueFox Posts: 15,250
    All components require vibration isolation, from power conditioner, to pre-amp, to CDP, to DAC, to file player, they all sound better with vibration elimination. I started out by using Mapleshade Micropoint brass footers on my gear. Later I upgraded my rack to a Mapleshade Samson V.3 four shelf rack. The shelves are solid maple, with six steel bars used for vertical support. Without gear, the rack weighs 400 pounds, with gear 700 pounds. Along with the brass footers, I feel I now have a good handle on minimizing distortion from vibration.
    I don't own a great "rack". lol But from what I've seen here, isolation and, especially, the various spike like decoupling devices are important. I don't worry about this that much in the main room because there the room is naturally treated for reflections, etc. And there is massive padding and carpeting all over it, plus I really "doubt" I could hear anything "subtle".
    I spent the weekend in NYC and attended a performance at Carnegie Hall. With my best listening skills I could NOT hear the kind of DETAIL some here have in their HIGHER end systems (some which often sound "bright" to my ears). The LIVE concert had NO irritating brightness to it and though you could certainly hear where the instruments where and depth of field it was NOT as EXAGGERATED as it is on a lot of systems that are "crystal clear". And it's not like the acoustics in this Hall are "bad". So what does that really mean about some of the sound heralded as LIVE that people claim they're approaching? Frankly, I don't know. But it reaffirms my preference for a "warmer" less crystalline and pristine sound. Because that IS what I heard! And it was "natural", not artificial.
    BTW! Having the boys in wood shop take on this project is a great idea, I slept my way through wood shop in my time (I was bored senseless by it). I think I would have a different perspective to it now! And a lot of guys here are ACES in the subject!
    Good Luck! And post some pics, later.
    cnh
  • Glen B
    Glen B Posts: 269
    Here's my old DIY 2-channel and HT system racks. Both were constructed of red oak, with MDF shelves. I painted the shelves matte black, and applied iron-on oak veneer to the edges, then clear lacquer. The bottom and top shelves of the 2-channel rack float on hidden spikes for vibration isolation.
    2ch_system2_zps42f1f09e.jpg~original
    102_zpse6b11392.jpg~original
  • boston1450
    boston1450 Posts: 7,758
    All the pics on this thread look very nice & sturdy. I myself will be building one soon. Keep the pics & ideas coming :)
    As far as spikes go-what is ideas on those with hardwood floors ? Spikes on plates ?
    Randy-Maine
    2ch-RTA15tl crossover upgrade
    by David WMG
    Yamaha cr1000 cr2040
    HT-Yamaha Parasound Acurus
    MIT BJC Cs1000p Polk Rotation
  • Glen B
    Glen B Posts: 269
    I use metal protection discs under spikes to protect my hardwood floors.
    disc_zpsb5a2e090.jpg~original
  • Hofy
    Hofy Posts: 169
    There is no one size fits all when it comes to a good rack for your gear. Vibration isolation, ventilation and the all important WAF need to be taken into consideration.
  • boston1450
    Thanks for pic Glen B. Thats a great idea if you decide to put down carpet & you can spike them or use disc. Is there a site i can order those from & see other ideas before tackling a project. I think i would be gearing more toward the size of your bottom pic above. Maybe with another shelf in the middle. I like the center speaker spot. Very nice. Thanks again
    Randy-Maine
    by David WMG
  • zingo
    zingo Posts: 11,258
    This is somewhat true as not all shelves/racks are deep enough to accommodate average audio components.
