My W4S DAC2 quit on me..
Toolfan66
Toolfan66 Posts: 18,188
edited February 2014 in Going Digital
So I'm playing some tunes off my laptop the only source I use with my DAC, and it just quit putting out sound.
It powers up, everything looks normal from just looking at it, but it no longer puts out sound, unless I'm missing something here but I don't get it. When I disconnect the laptop sound will come out of its speakers..
I'm really bummed as I hate shipping gear to be fixed, yes it's still under warranty..
Post edited by Toolfan66 on
  • erniejade
    erniejade Posts: 6,321
    WOW. I am suprised. I have had mine for about 1.5 years without any issues. Maybe get the dsd upgrade while its in the shop!!
    Have you checked to make sure the souce is ok? Were you using it fix or Variable ?
    SCompRacer Posts: 9,122
    Mac or Windows laptop? Update or change anything of late? Mac had some software issues that were addressed.
    SCompRacer wrote: »
    Windows, and I haven't changed anything, this laptop is only used for music only, never surf the net or anything, I even swapped USB cables just in case, and nothing.
    I'm going to try another source tonight, but I still think something is up.
    I talked to Clint this morning, he said if that doesn't work get it ready to ship back and he will fix it..
  • Face
    Face Posts: 14,340
    First time I've heard of one of these failing. Good luck Larry.
    My DAC is fine!!!!
    I left it unplugged all day while at work, came home started from scratch, reloaded the software, set my DAC to fixed, and BAM!! Working like a charm..
    Not sure what happened but I will keep an eye on it...
  • erniejade
    Sweet!! If you ever figure out what happened let us know.
    I will do, all day long I kept telling myself there is no way it's the DAC, I think it was a glitch in the laptop..
  • VCoak
    VCoak Posts: 200
    Larry,
    Have you looked at the W4S DAC-DSDse??? I am very close at buying either the se or the DSD. Opinions on the se? Some threads love it some say beyond the 64 (128) not so good.
    The DAC will be for a home digital music server. Currently an old hp laptop but waiting to see what the mac mini's will look like.
    mco
    W4S SX-1000, Adcom gfp-750, Polk 1.2tl, W4S DAC 2 DSDse, 2012 mac mini (mod), JRivers ver. 19, WD Cloud NAS 2 t.b., Monster Cable AVS-2000 signature, Doug's Alpha I/C & Doug's biwire 6' speaker cables
    heiney9 Posts: 25,504
    99% of the time it's software related when it comes to USB and a computer for audio. Glad it worked out for you.
