Built in powered subwoofer sounds full range
Mystery
Mystery Posts: 2,546
edited February 2014 in Electronics
The built-in subwoofer in my KSP-400 were working fine but yesterday when I turned them on, one subwoofer sounded full range.
The level and crossover controls also don't make any difference.
The other one is working fine as it should.
What could be the issue?
Post edited by Mystery on
  • Mystery
    Hmm... am I the only one with this kind of problem?
  • aboroth00
    aboroth00 Posts: 1,108
    Never heard of that before. Usually when a XO fails, there's no sound.
    2Ch Tube Audio Convert
  • Mystery
    The amp is working as well as the woofer but it sounds like another small midrange speaker instead of the 15" sub.
    Level control doesn't work.
    Just like the amp is hooked up directly without any crossover.
    Weird.
