Built in powered subwoofer sounds full range
Mystery
The built-in subwoofer in my KSP-400 were working fine but yesterday when I turned them on, one subwoofer sounded full range.
The level and crossover controls also don't make any difference.
The other one is working fine as it should.
What could be the issue?
Post edited by Mystery on
Hmm... am I the only one with this kind of problem?
Never heard of that before. Usually when a XO fails, there's no sound.2Ch Tube Audio Convert
The amp is working as well as the woofer but it sounds like another small midrange speaker instead of the 15" sub.
Level control doesn't work.
Just like the amp is hooked up directly without any crossover.
Weird.
