SurroundBar TOSlink/optical cable heads
tnvmv
Hi all,
Got my SurroundBar 9500BT and absolutely love it.
The included optical/TOSlink cable works great, however there is such a small amount of space for the head for any new cable to fit. I've had to return a pair I already bought. The clearance for the head of the cable is about 7/8" and the basic cable heads at all stores I've checked are over 1"
Anyone have the same problem or know where I can purchase optical cables that will fit in the space?
Thanks in advance,
tnvmv
Thanks in advance,
tnvmv
Post edited by tnvmv on
Looks great!
Cmgindustry wrote: »Looks great!
Really? That was helpful.... -
Hello,
Welcome to Polk's forum. I would imagine if you gave Polk's CS guys a call they would happily send your another cable just like the original. They are at: 1-800-377-7655 or via email to: polkcs@polkaudio.com.
Cheers, Ken -
Kenneth Swauger wrote: »Hello,
Cheers, Ken
Thanks for the idea, I called them and they had a better idea, a 90 degree adapter. Gonna buy a couple for the bar.
Thanks!
