SVS Subwoofer Choice!! Or something else??
Toolfan66
Toolfan66 Posts: 18,082
I am in the market for a subwoofer, I haven't owned anything but Polk sub's, so I have been looking at the SVS SB13, or PC13 Ultra. I will be using it 90% HT very seldom do I listen to music in my HT rig.
Should I just save a few bucks and go for the PB12 Plus? Or is there another sub I should consider?
Like I said I don't have any experience with any other sub's but my Polk's.
I own the DSW 500 and the DSW 600, the 500 gave out on me, and purchased a new amp from Polk, but since then my 600 gave out on me, and I don't want to fix it, I would like to go with a better subwoofer, and I have heard nothing but good things about SVS.
Thanks in advance..
Post edited by Toolfan66 on
  • aboroth00
    aboroth00 Posts: 1,106
    edited February 2014
    I have been hearing very good things about Rythmik recently and almost pulled the trigger on some dual pairs but came to my senses. http://www.rythmikaudio.com/FV15HP.html
    It holds its own against the SVS and bests it in overall output. I haven't heard anything bad about it and all reviews are generally positive. However, I must say I have no direct experience with either model. It's cheaper than the Ultra by a good margin, but you don't get the chance to try it out in the comfort of your home without being responsible for the shipping charges.
    If you can accommodate two subs, it'll probably be advantageous to get two over one.
    2Ch Tube Audio Convert
  • danz1906
    danz1906 Posts: 5,144
    The SVS SB-13 Ultra is a Great sub for HT!!!
    Linn AV5140 fronts
    Linn AV5120 Center
    Linn AV5140 Rears
    M&K MX-70 Sub for Music
    Odyssey Mono-Blocs
    SVS Ultra-13 Gloss Black:D
  • dbKiller
    dbKiller Posts: 316
    I have a PB12 Plus 2, its healthy. Sometimes after a good explosion scene I halfway expect to find drywall damage in the corner its in. This is my first real sub so I don't have much to compare it with, but never even used at over 3/4 power and it always surprises like its the first time I have ever heard it. Im an SVS fan now for sure.
    Home Theater: LG 60PB450; Pioneer Elite SC55; RT2000P; RT55P; CS400p; FX500; SVS PB12-Plus/2; PS3 360GB
    Office: Onkyo TX-NR616; RT2000i; RT800i; CS400i; DSW Micropro 4000; XBOX 360 250GB; LG BR370; Panasonic Plasma
    Bedroom: Sony STR-DH820; CS400p; RT55p; Sony Grand Wega 55"
    Retired: Sony STR-DN840; Yamaha HTR-6130; Sony STR-DN520; Paradigm Phantom V.3; Paradigm CS-270V.3, Cinema ADP V.3, PS1000 V.4; Polk S6; Onkyo TX-NR809; Monitor 50, CS1; FXi3; PSW350
    VR3 Posts: 29,448
    Agreed, build one.
    TC Sounds LMSR 12 with dual LMSR 12 PRs - shake and bake baby! Shake and bake!
    txcoastal1 Posts: 13,513
    VR3 wrote: »
    Agreed, build one.
    Or a pair of sealed TC sounds 12" LMSR's
    The 18" TC sound at Skips last weekend was pretty sweet, and I'm not a bass head but makes you want some.
  • Inspector 24
    Inspector 24 Posts: 1,308
    HSU VTF-15h is favorably compared to all of those subs and regarded as possibly the best bang for the buck, While the PB-13 Ultra is absolutely a better sub, you can you can buy two VFT-15h's two for less than one SVS PB-13 ultra and get better, more even room response that multiple subs provides.
    In other words Dual HSU > PB13 Ultra <> Rhythmic > Single HSU.
    I love my dual subs, amazing at filling out the bottom end of my music and completely invisible unless I want to hear them. Awesome thump and rumble for movies, and turns the basement into a dance club when I want it. And multiple port configurations and Q settings allow one to tune the sound to your liking for whatever you listen to.
    More than you ever wanted to know about the HSU, and great graphs to directly compare other subs:
    http://www.data-bass.com/data?page=system&id=100
    Up
    LSi15 LSiC - RX-V3000
    Down
    Sim2 D60 - Dragonfly 106" Panny 500
  • WLDock
    WLDock Posts: 3,073
    DSkip wrote: »
    Build one man! You've got the skills.
    If you can put things together and have the time and willl...DIY is the way to go to get the most for the dollar! Yes, the Ultra sounds like a killer sub....but $1700 for one? $1750-$1950 for Dual Drive VTF-15H?
    I just posted this in another thread:
    2 x Stereo Integrity HT 18" = $324
    2 x DIY Sound Group 4 cu ft sealed flatpack = $240
    1 - Peavey IPR2 2000 = $350
    1 - MiniDSP Balanced =$125
    1 - UMIK-1 USB measurement mic = $75
    1 - R.E.W. software = free
    = $1114 + what else one might need.
    Data - (Look how nice the big sealed sub compares to the ported PB-13 Ultra and VTF-15H)
    http://www.data-bass.com/data?page=driver&id=46
    http://www.data-bass.com/data?page=system&id=90
    Motivational builds:
    http://www.hometheatershack.com/forums/sealed-subwoofer-build-projects/64052-stereo-integrity-ht-18d2-build.html
    http://www.avsforum.com/t/1481968/fusion-10-max-stereo-integrity-ht-18-d2-build-thread
    http://www.avsforum.com/t/1463064/16-x-18s-in-a-1500ft-3-space-popalocks-sub-build
    http://www.hometheatershack.com/forums/sealed-subwoofer-build-projects/67838-stereo-integrity-18-d2-curved-build.html
    http://www.avsforum.com/t/1453468/stereo-integrity-18-d2-build-sealed
    http://www.avsforum.com/t/1489523/si-18s-6-in-sono-tubes-build-is-done
  • kuntasensei
    kuntasensei Posts: 3,263
    Though I love my older SVS rig dearly, the staff changes and change of direction there have me concerned. If I had my druthers right now, I'd check out a sub from Power Sound Audio - the company that one of SVS' founders spun off when he left. They seem to be more focused on killer bass on a budget than SVS is these days.
    Equipment list:
    Onkyo TX-NR3010 9.2 AVR
    Emotiva XPA-3 amp
    Oppo BDP-93 Blu-ray player
    Epson 8500UB 1080p projector
  • WLDock
    WLDock Posts: 3,073
    Yeah, PSA seems to offer a better value on paper. never heard their sub though but would like to.
  • blehmbo
    blehmbo Posts: 179
    Consider Rythmik's offerings. I went from a DSW500 to a F15HP and have no regrets. It's really in a different league. If you want to go the DIY route they also offer custom install servo sub kits.
  • WLDock
    WLDock Posts: 3,073
    mikeyb wrote: »
    I just ordered an svs sb13 ultra.
    Nice! Thats the one I think is sexy!
  • danz1906
    mikeyb wrote: »
    I just ordered an svs sb13 ultra.....I spent about a month trying to decide. My plan is to run 2 of these. I will let you know on Wednesday how just one will do. I am upgrading from dual dsw500's (which I have sold) I do have a micro pro as well... I can barley make it through work day without checking the tracking number at least 7 times.
    Great Choice!
    Linn AV5140 fronts
    Linn AV5120 Center
    Linn AV5140 Rears
    Odyssey Mono-Blocs
  • Mikey081057
    Mikey081057 Posts: 7,127
    Congrats Mikeyb and yes 2 subs are better for sure.
    Has anyone checked these out?
    http://www.aperionaudio.com/bravus-ii-12d-powered-subwoofer
    They get VG reviews, and some have said blow the REL 528SE away at like 1/3 the price
    Garage | Polk Monitor 5B's
  • Tornado Red
    Tornado Red Posts: 939
    I'm running the DSW 550 and 660 for now and I'm pleased, but down the road I'd like to upgrade with a couple from ideas here (Rhythmik and SVS come to mind)....also I'm hearing good things and may look at this:
    PSB Subseries 500
    PSB Subseries 500
    http://www.canuckaudiomart.com/details/648960392-psb_subseries_500_subwoofer
  • falconcry72
    falconcry72 Posts: 3,580
    Don't count out the SVS PC12-NSD... huge performance for the price... especially if the lower price allows you to run duals.
    dual NSDs > single Plus; dual Pluses > single Ultra.
    I say get dual NSDs and see what you think; they are true performers and will knock the socks off your DSWs... I should know, I used to run a 600. If you're not 100% satisfied with the NSDs, you have 12 months to upgrade to dual Pluses or anything else.
  • Inspector 24
    Here's a great thread that helped me settle on the HSU and eventually a 2nd.
    http://www.avsforum.com/t/1307657/how-the-svs-pb13-ultra-compares-to-hsu-vtf-15h/0_100
    If you want ultimate output then the SVS PB-13 Ultra is the droid you are looking for.
    After reading more than a few comparisons suggest the HSU had more finesse, more liveliness for music I was sold.
    Ultimately, any sub you're looking at is going to kick the pants of any Polk Sub. I had three PSW505's and just one VTF-15h put them all to shame.
    Up
    Down
  • Tornado Red
    txcoastal1 wrote: »
    Wonderful. Thanks for that. Now my wallet is starting to quiver....
  • falconcry72
    So I take it you're digging the VTF-15h? Did you consider the ULS-15?
  • WLDock
    WLDock Posts: 3,073
    Epik has several very well speced 12", 15", 18" drivers at crazy low prices $75-$99. Would make for a very cheap diy build.http://www.epiksubwoofers.com/blog/
    I doubt they will last long...
    Thanks for all the feedback guys, really gives me something to think about...
  • dkg999
    dkg999 Posts: 5,647
    I'm not sure why you want a sealed box sub for HT? I have the SVS SB12+ in my 2 ch rig, great sub, however either of my other SVS ported subs are much better for HT.
    I am surprised no one mentioned some of the best sub's out there ..... the Paradigm Servo line. Expensive new, however there are usually pretty good deals on demo and used.
    DKG999
    There's another add in Canuck for a pair at $1600....thats the one that made my wallet quiver
  • WLDock
    WLDock Posts: 3,073
    dkg999 wrote: »
    On no doubt ported is great for HT. However, depending on room size, taste, driver, etc. one might opt for a large driver in a sealed enclosure. With the right driver, high output clean, tight, and low bass is possible.
    here is a graph of the SI HT18 (BLUE) vs. the PB-13 Ultra 15Hz tune(PURPLE)
    SI HT 18 (BLUE) vs. HSU VTF-15H (PURPLE)
    With some shaping of the low end the sealed sub should do just fine with good power behind it. Add a second in most modest sized rooms with some decent room gain, I would think that they would shake the foundation more than enough for most out there.
  • WLDock
    WLDock Posts: 3,073
    Not yet. Need to get the garage and basement organiztion project done first. However, I plan to order the enclosure next week. I was going to pick up a Dayton SA1000 amp that I had a line on for $200 but now I'm not so sure. I might get a used Samson S1000 or SX1800 pro amp and mod the fans. This way, if I decide to add a second one I will already have the power. I just don't have the space for a second sub right now.
  • Inspector 24
    Considering the VTF is the better dual use (movies/music) subwoofer, and has more output, good for my 5,000+cuft room, it was easy to decide. And I liked the thought and now practical application of being able to 'tune' it to my preferences.
    And yes, I freaking love them. I'm guessing I would have to spend a lot of money on an upgrade to get a big improvement. And/or get a better room. :p
    Up
    Down
  • Inspector 24
    Good info on the ULS vs VTF:
    http://www.avsforum.com/t/1366339/uls-15-vs-vtf-15h
    http://forum.hsuresearch.com/showthread.php?t=95433
    ^^^Dr HSU himself recommends the VTF for larger room dual purpose use. But prefers the ULS for music.
    Up
    Down
  • WLDock
    WLDock Posts: 3,073
    Yeah, I read the same thing about the two subs. There are some out there that love the ULS but don't like the VTF? Go figure.
    Anyway, my room is medium sized and the system is 50/50 dual. I have always liked the quality of a sealed or infinite baffle sub. Using a modern large stroke, high BL 15-18" driver, some seriously large and clean bass can be had. Its just amazing when done right.
