gnx104 rattle
rodney
rodney Posts: 91
edited July 2004 in Car Subwoofer Talk
im running 2 gnx 10s in a seal box, with seperate chambers, and one of them rattles some when i turn the bass boost on the amp up. it doesnt sound like the music is distorting any, so i dont think its busted, it just sounds like the outside of the sub is vibrating. is this a problem, will it damage the sub at all? thanks
alpine cda-9857
polk db6500
polk ex369
polk/momo mm104
profile ap1040
kenwood kac-7251
Post edited by rodney on
  • exalted512
    exalted512 Posts: 10,734
    edited July 2004
    bass boost=sub killer
    -Cody
  • Systems
    Systems Posts: 14,872
    edited July 2004
    i had the same prob with mine and it ended up bein the wire from the cone to the terminal..id check that out
    Testing
    Testing
    Testing
  • neomagus00
    neomagus00 Posts: 3,899
    edited July 2004
    ah, yes, tinsel slap... good times with loose wires... if it sounds like it's that little wire inside the sub banging against the cone 50 times a second, then you're safe... annoyed, perhaps, but safe... and yeah, bass boost is dangerous unless used sparingly and intelligently; for example in order to add a couple dBs down low (30-40 Hz) to compensate for your sealed box's inherent weaknesses...
