gnx104 rattle
rodney
im running 2 gnx 10s in a seal box, with seperate chambers, and one of them rattles some when i turn the bass boost on the amp up. it doesnt sound like the music is distorting any, so i dont think its busted, it just sounds like the outside of the sub is vibrating. is this a problem, will it damage the sub at all? thanks
alpine cda-9857
polk db6500
polk ex369
polk/momo mm104
profile ap1040
kenwood kac-7251
polk db6500
polk ex369
polk/momo mm104
profile ap1040
kenwood kac-7251
Post edited by rodney on
bass boost=sub killer
i had the same prob with mine and it ended up bein the wire from the cone to the terminal..id check that outTesting
Testing
Testing -
ah, yes, tinsel slap... good times with loose wires... if it sounds like it's that little wire inside the sub banging against the cone 50 times a second, then you're safe... annoyed, perhaps, but safe... and yeah, bass boost is dangerous unless used sparingly and intelligently; for example in order to add a couple dBs down low (30-40 Hz) to compensate for your sealed box's inherent weaknesses...It's not good, very fundamentally simply not good. - geolemon
