Stillpoints
BlueFox
Anyone use Stillpoints under their gear?
I am a big fan of vibration control on gear after hearing what Mapleshade brass footers did to the sound. Currently, except for the amps, I have Mapleshade Micropoint brass footers under all my gear, including the HT. Anyway, on other forums Stillpoints seem to rule, so I am thinking of trying some. The issue is the Mapleshade Micropoint footers cost $185 for three, while Stillpoints Ultra SS are $250 each. So, I am doing my research for opinions. Thanks.
If I do get some I will start with three and put them first on the Triton, evaluate, move them to another piece, evaluate, etc.
Post edited by BlueFox on
Just my personal opinion and it really doesn't mean nada, but I feel the law of diminishing returns come into play with Stillpoints.2-channel: Modwright KWI-200 Integrated, Dynaudio C1-II Signatures
That is what I am wondering. The Micropoints make a big difference, so I wonder what improvement over that the Stillpoints will provide. What gear have you used with Stillpoints?Lumin X1 file player, Westminster Labs interconnect cable
Three 20 amp circuits. -
I haven't used in my personal system just played with them at Hi-fi store
I prefer just using isolation/decoupling products like Black Diamond
http://www.bdrsound.com/Home_Page.html
You can also mix the pads with standard brass cones or pucks2-channel: Modwright KWI-200 Integrated, Dynaudio C1-II Signatures
