Stillpoints
BlueFox
BlueFox Posts: 15,250
edited January 2014 in Electronics
Anyone use Stillpoints under their gear?
I am a big fan of vibration control on gear after hearing what Mapleshade brass footers did to the sound. Currently, except for the amps, I have Mapleshade Micropoint brass footers under all my gear, including the HT. Anyway, on other forums Stillpoints seem to rule, so I am thinking of trying some. The issue is the Mapleshade Micropoint footers cost $185 for three, while Stillpoints Ultra SS are $250 each. So, I am doing my research for opinions. Thanks.
If I do get some I will start with three and put them first on the Triton, evaluate, move them to another piece, evaluate, etc.
Post edited by BlueFox on
    txcoastal1 Posts: 13,519
    edited January 2014
    Just my personal opinion and it really doesn't mean nada, but I feel the law of diminishing returns come into play with Stillpoints.
  • BlueFox
    edited January 2014
    That is what I am wondering. The Micropoints make a big difference, so I wonder what improvement over that the Stillpoints will provide. What gear have you used with Stillpoints?
    edited January 2014
    I haven't used in my personal system just played with them at Hi-fi store
    I prefer just using isolation/decoupling products like Black Diamond
    http://www.bdrsound.com/Home_Page.html
    You can also mix the pads with standard brass cones or pucks
