Which sda do u want or prefer? & why
13»
    F1nut Posts: 51,687
    edited January 2014
    All Major brands of receivers are common grounded
    That is true.
    and are virtually all integrated and separate amplifiers are common grounded."
    Not true.
    "Very Few amplifiers are not common grounded and are usually marked with some warning near the output terminals"
    Not true. I've never seen an amp marked that way, ever.
    You just can't believe everything you read, even from Polk. :eek:
  • boston1450
    boston1450 Posts: 7,758
    edited January 2014
    Definitely worth asking here or call manufacturer, just to be sure. Ive read some archived stuff here on CP on the Adcoms & common ground questions. Interesting post too
    Randy-Maine
    2ch-RTA15tl crossover upgrade
    by David WMG
    Yamaha cr1000 cr2040
    HT-Yamaha Parasound Acurus
    MIT BJC Cs1000p Polk Rotation
  • Hofy
    Hofy Posts: 169
    edited January 2014
    I think the 7s with proper stands will be perfect. The CRSs would work as I said, but you're doing them an injustice in a cramped space.
    Thanks for the replies. It looks like I was on the right path with my thinking. Of course, if I should happen to stumble upon some SDAs for a cheap price they will be coming home!
