amps to pre amp
tred2014
tred2014 Posts: 4
hi i am fairly new to component stereos and i need some input on what i want to do.i have 1 qsc usa 900 amp, 1 qsc mx1500a amp, and 1 museatex acc pre amp which has twin outputs [four].and 1 set cerwin vega d9 speakers and one set cerwin vega v 153 speakers.is it as simple as plugging one set of outputs from pre amp to one amp, and the same for the other, set the gains on the amps to match, connect two speakers to each amp and im ready to rock? thnx
Post edited by tred2014 on
  • spotty
    spotty Posts: 5
    edited January 2014
    I a word, Yes !
  • tred2014
    tred2014 Posts: 4
    edited January 2014
    thank u both for your responses.nbrowser could u please go into some detail about your response so i can fully understand and maybe try to correct those issues? thnx
    F1nut Posts: 51,699
    edited January 2014
    Using pro gear and speakers that are not known for their sound quality is going to result in a lot of bad sound, IMO.
    Running 2 pair of stereo speakers together will cause soundwave cancellations, known as comb filtering and will result in even worse sound quality.
    tonyb Posts: 33,068
    edited January 2014
    Especially 2 pair of speakers that aren't the same.
  • tred2014
    tred2014 Posts: 4
    edited January 2014
    ok i c thanks again for your input.i thought i read something about when using 4 speakers with the museatex acc pre amp, to install thr fourth speaker with reversed polarity at the speaker.could any one explain this so i can understand? thnx
  • tred2014
    tred2014 Posts: 4
    edited February 2014
    also, just found out that quarter inch music plug for inputs on amp have neg tip as opposed to pos.also they are 3 wire and i assume rca on pre amp is 2 wire tip pos.one, can i get adapter that will change polarity at plud tip going into amp? and what about the fact quarter inch plug that goes to amp has ground? any input would b greatly appreciated thnx
