Question about Pioneer SX-737 receiver -
dromunds
I have a friend with a Pioneer SX-737 receiver who says the "radio bleeds into the phono and auxiliary. Anybody have any thoughts on what's going on? Also, can she connect a separate preamp to that receiver? Thanks in advance for any help.
Post edited by dromunds on
I do believe radio shack has them (phono pre-amp) & can be hooked into AUX or TAPE if aux is messing up to. Or have it serviced is the best bet
EDIT- have you tried deoxit on the controls ?Randy-Maine
2ch-RTA15tl crossover upgrade
by David WMG
Yamaha cr1000 cr2040
HT-Yamaha Parasound Acurus
I don't think that the SX-737 has pre out/main in connections; I know that the previous model year's SX-727 does not.
www.hifiengine.com may well have the manual.
The radio bleed is an odd problem - maybe an issue with a dirty function selector switch? -
Hello,
One approach would be to select the FM muting button on the upper right of the front panel, then de-tune whatever radio station was selected. In effect putting the receiver's tuner between stations and with the muting engaged there won't be any sound. Then select phono or auxiliary with no interference.
Ken -
That is a cheap and effective fix for sure. Nice save amigo.
Thanks a lot guys. I'll pass on that suggestion Ken!
I hope it helps your friend. Many internal input selectors will short out any non-selected sources, leaving the selected source connected. The problem can be with units that allow for one source to be recorded (or chosen as a second "zone" source) and another source chosen for main listening. This design would use a non-shorting selector and there could be bleeding of strong inputs.
Cheers, Ken -
nice call, sir... obvious, but only in retrospect! :-)
This problem accompanied Carver HR-752 receivers right out of the box in the early 90's. There were a lot of them.
That wasn't an uncommon problem with receivers in the 70's/80's. I used to do what Ken mentioned, because I am supremely anal about background interference/noise.Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2
Any update on this receiver ? I talked to my friend who has this very same receiver & he had the same issue & it came right out of it when he cleaned all the buttons & knobs. He has it hooked to a new turntable & tape player & is listens to FM alot. He really enjoys the Pioneer alot.Randy-Maine
by David WMG
Boston: I passed on the suggestions and awaiting her response.
Cool. Hope she gets it fixed. Those are built nice & will go for years. Worth servicingRandy-Maine
by David WMG
Over the decades lots of pre-amps had input cross-talk issues. Typically it happens when one input has a strong signal and then they switch to an input that has nothing connected to it. Try plugging a music sourch into the input, set the level for reasonable loud, then pause the music.
Almost all Pioneer silver face, Sansui, Kenwood, Technics and Realistic receiver of that time that I had always came with radio bleed.
I had to use Phono button activated for a clean sound from other inputs.
