Loose Spike Inserts - LSi15
skrol
I was noticing that the inserts that are screwed into the base of my LSi-15's wobble around quite a bit reducing the stability of the speaker. Obviously this is counter productive. Anyone have this issue? Any tips on securing them?
Stan
Stan
Stan
Main 2ch:
HT:
Other stuff:
Main 2ch:
HT:
Other stuff:
Post edited by skrol on
Epoxy, make sure to keep it out of the threads.Political Correctness'.........defined
President of Club Polk -
Cool!
.....ThanksStan
Main 2ch:
HT:
Other stuff:
If you use the 5 minute version it'll still need 24 hours for a full cure. Epoxy with a longer open time will be stronger, so use that if you can.
It would be best to unscrew the inserts, apply epoxy to the sides of the holes and inserts, screw back in. If you get epoxy in the threads run the spikes into the threads and back out again. Wipe off any epoxy, repeat until there is no more epoxy on the threads.Political Correctness'.........defined
