Loose Spike Inserts - LSi15
skrol
skrol Posts: 3,488
edited January 2014 in DIY, Mods & Tweaks
I was noticing that the inserts that are screwed into the base of my LSi-15's wobble around quite a bit reducing the stability of the speaker. Obviously this is counter productive. Anyone have this issue? Any tips on securing them?
Stan
Stan
Main 2ch:
HT:
Other stuff:
Post edited by skrol on
    F1nut Posts: 52,301
    edited January 2014
    Epoxy, make sure to keep it out of the threads.
  • skrol
    skrol Posts: 3,488
    edited January 2014
    Cool!
    .....Thanks
    Stan
    Main 2ch:
    HT:
    Other stuff:
    F1nut Posts: 52,301
    edited January 2014
    If you use the 5 minute version it'll still need 24 hours for a full cure. Epoxy with a longer open time will be stronger, so use that if you can.
    It would be best to unscrew the inserts, apply epoxy to the sides of the holes and inserts, screw back in. If you get epoxy in the threads run the spikes into the threads and back out again. Wipe off any epoxy, repeat until there is no more epoxy on the threads.
