Dac's in series...
brgman
OK i'm getting a headache trying to figure this out.I looked around but haven't found my answer.
Example:When using a DAC it takes digital to analog.This of course means no digital out to another DAC.I get this.
Enter the SB Touch as an example now.I feed with an ethernet which carries a digital signal to the Touch.I then run a coaxial cable from the o/p of the Touch to the OPPO.
How is this bypassing the DAC in the Touch?
How is it giving me a digital signal to the Oppo?
Why wouldn't you only be able to pull analog from the Touch if it gets processed by an onboard DAC?
I’M OFFENDED!!!!
I’M OFFENDED!!!!
Post edited by brgman on
The SB Touch isn't a standalone DAC.....it's a network streamer basically. You're sending digital in and whatever you want out....in your case digital out. All the networkable streamers are like this. They all have built-in DAC's but you can send the digital out to a standalone DAC.2 channel - Willsenton R8 tube integrated, Holo Audio Spring 3 KTE DAC, audio optimized NUC7i5, Windows 10 Pro/JRiver MC29/Fidelizer Plus 8.7 w/LPS and external SSD drive, PS Audio PerfectWave P3 regenerator, KEF R3 speakers, Rythmik F12SE subwoofer, Inakustik Reference USB cable, Gabriel Gold IC's, Morrow Audio SP5 speaker cables. Computer - Windows 10/JRiver, Schiit Magni 3+/Modi 3+, Fostex PMO.4n monitors, Sennheiser HD600 headphones
I'm trying to figure out how that happens without any special settings.It seems to me any unit with a DAC will want tto run the signal through.
An AVR also offers digital out in the same fashion.I am just too stubborn or dumb to understand how this works.Main Rig-Realistic AM/FM Record player 8 track boasting 4 WPC
I’M OFFENDED!!!! -
Any time you use a coaxial or optical out it is digital out bypassing that DAC's device until you use analog cables
You are mind f*^#ing yourself2-channel: Modwright KWI-200 Integrated, Dynaudio C1-II Signatures
txcoastal1 wrote: »Any time you use a coaxial or optical out it is digital out bypassing that DAC's device until you use analog cables
I know, but how???????????
How does that little chip know what i want???Main Rig-Realistic AM/FM Record player 8 track boasting 4 WPC
I’M OFFENDED!!!! -
Its different circuit outputs2-channel: Modwright KWI-200 Integrated, Dynaudio C1-II Signatures
It's actually sending the signal to both the digital and analog outputs but it's sending a DAC-bypassed digital signal to the digital out and a DAC converted analog signal to the analog outputs. Unless, of course, you turn off the analog outputs completely, which is an option.2 channel - Willsenton R8 tube integrated, Holo Audio Spring 3 KTE DAC, audio optimized NUC7i5, Windows 10 Pro/JRiver MC29/Fidelizer Plus 8.7 w/LPS and external SSD drive, PS Audio PerfectWave P3 regenerator, KEF R3 speakers, Rythmik F12SE subwoofer, Inakustik Reference USB cable, Gabriel Gold IC's, Morrow Audio SP5 speaker cables. Computer - Windows 10/JRiver, Schiit Magni 3+/Modi 3+, Fostex PMO.4n monitors, Sennheiser HD600 headphones -
dragon1952 wrote: »It's actually sending the signal to both the digital and analog outputs but it's sending a DAC-bypassed digital signal to the digital out and a DAC converted analog signal to the analog outputs. Unless, of course, you turn off the analog outputs completely, which is an option.
Well that was easy.I should've thought of this.
I guess I picked the wrong week to stop sniffing glue.
Thanks.Main Rig-Realistic AM/FM Record player 8 track boasting 4 WPC
I’M OFFENDED!!!! -
I thought that was last week when you sent me that tex.Mcintosh MC-501 mono blocks
Mcintosh C-45
Mcintosh MVP-871
PS AUDIO AV5000
MIT 3.3 Shotgun biwire speaker interface
MIT 3.3 Shotgun XLR interconnects
Polk 2.3TL's Gimpod boards/F-1 modded crossovers/dynamat/JB weld/Larry's rings/Blackhole 5 strips
Polk 3.1 TL's mint/stock (purchased new)
Polk SDA-2's -
brgman wrote:I know, but how???????????
How does that little chip know what i want???dragon1952 wrote: »It's actually sending the signal to both the digital and analog outputs but it's sending a DAC-bypassed digital signal to the digital out and a DAC converted analog signal to the analog outputs. Unless, of course, you turn off the analog outputs completely, which is an option.
Just to clarify....as for the digital signal, when I said "It's sending the signal" I meant the SB Touch, not the 'little chip' :^ ) The 'little chip' is just sending the analog signal, but both signals are being sent to their respective outputs regardless of which one you are using. So you could actually have more than 1 device connected to the Touch at the same time.2 channel - Willsenton R8 tube integrated, Holo Audio Spring 3 KTE DAC, audio optimized NUC7i5, Windows 10 Pro/JRiver MC29/Fidelizer Plus 8.7 w/LPS and external SSD drive, PS Audio PerfectWave P3 regenerator, KEF R3 speakers, Rythmik F12SE subwoofer, Inakustik Reference USB cable, Gabriel Gold IC's, Morrow Audio SP5 speaker cables. Computer - Windows 10/JRiver, Schiit Magni 3+/Modi 3+, Fostex PMO.4n monitors, Sennheiser HD600 headphones
