humming noise watching tv????
jaf09
jaf09 Posts: 48
edited January 2014 in Troubleshooting
it is only when i watch the tv, anybody knows why, thanks!!!
Post edited by jaf09 on
    F1nut Posts: 52,009
    edited January 2014
    You need to provide a lot more info than that.
  • polkfarmboy
    polkfarmboy Posts: 5,703
    edited January 2014
    jaf09 wrote: »
    Try unplugging everything in your room from the outlets and keep only the tv plugged in and report back if you still hear it.
  • AsSiMiLaTeD
    AsSiMiLaTeD Posts: 11,728
    edited January 2014
    Is the noise coming from the tv itself? Is it by chance a plasma?
  • fun_dador
    fun_dador Posts: 28
    edited January 2014
    Any other info you can provide... These Polkies are so eager helping out...
  • jaf09
    jaf09 Posts: 48
    edited January 2014
    Hi guys, sorry for the delay,the tv is fine is when i use the home teather tv input,but only when i watch the tv... ,ps3, blu rays, ipod anything else works fine .
    Thank you all for the help
  • rpf65
    rpf65 Posts: 2,127
    edited January 2014
    Assuming your running HDMI cable from TV to AVR, try switching it out.
  • jaf09
    jaf09 Posts: 48
    edited January 2014
    rpf65 wrote: »
    yes but i only have the one on the receiver hdmi out to the tv so anything i plug to the avr goes through it, but i have rca audio output to tv input in the receiver to hear the cable through the tv.
    I had it like that in my old apartment but i moved and this started to happened ,i swear it worked fine for like an our or so and then hhhmmmmmmm is in the background of the normal sound but is very annoying,
  • rpf65
    rpf65 Posts: 2,127
    edited January 2014
    Check to make sure that all coax connections are tight, if that doesn't work, get an extension cord and try a plug from a different room. Your looking for a plug that gets power from a different circuit breaker. Try the TV, not the other components on that plug. If still no change, try different RCA cables.
    You can try these in any order.
  • jaf09
    jaf09 Posts: 48
    edited January 2014
    rpf65 wrote: »
    i just was gonna try the extension cord to the tv but notice that when turn the tv off the humming dont stop any ideas. Cut it be that i need a power sourge protector in this place? oh and also notice the humming is lower today..
    All conecctions seem to be tight and i did replace the rca and improve a little
  • rpf65
    rpf65 Posts: 2,127
    edited January 2014
    Need to isolate the component. Unplug everything connected to the AVR, and power connections sharing the same plug. If you hear the hum its related to the AVR. If not, start adding components one at a time until the hum comes back.
  • leftwinger57
    leftwinger57 Posts: 2,917
    edited January 2014
    jaf, I wire my tv pretty much the same way you do.1HDMI cable from tv directly into the cablebox.The 2nd HDMI cable from the output of my Yamaha 665 avr back to the tv to pick up onscreen YPAO and do any adjustments that way which is better than trying to read the led screen on the avr. Then I run either an optical or RCA from cable box to av1 or audio 1 on the avr for audio.This way I can mute audio and still have tv and tunes going at the same time. When I 1st bought the thing about 6years ago I thought that was the function of the HDMI cable and learned it wasn't and have to do it this way.I would check your cables for the noise problem,then as others said do a process of elimination.
