Well, now the PC issues are ok an ice maker in the fridge question arises...
starkiller
Ice maker in Whirlpool Gold fridge making plastic clicking noises, like gears turning. Ice not being made. Scoped it out and at the rear of the ice-maker, wedged at the very edge was a cube. Finally got that dislodged but the clicking sounds are still there, whether the arm is up or down. Amazing how such a small sound gets really really annoying after hearing it for some hours
Thoughts??
Thoughts??
Computer room Hegeman 1 SpeakersM&K VX-80 subKenwood DP-7010Cambridge Audio CXC Transport Rega DACPrimaLuna Prologue Four AmpAric Audio Tube PreampGarage Jennings Research SquareCustom tube preampCrown XLS-1000Denon DCD-1500II Modded MSB Link DAC
Post edited by starkiller on
I put my refrigerator in the garage so that I didn't have to listen to its noises.Lumin X1 file player, Westminster Labs interconnect cable
Three 20 amp circuits. -
That would be great if I had the room and the wife wouldn't notice it was gone
Computer room Hegeman 1 SpeakersM&K VX-80 subKenwood DP-7010Cambridge Audio CXC Transport Rega DACPrimaLuna Prologue Four AmpAric Audio Tube PreampGarage Jennings Research SquareCustom tube preampCrown XLS-1000Denon DCD-1500II Modded MSB Link DAC -
It opened up space in the kitchen for a nice wine rack. Once you get used to it, you don't mind going to the garage.Lumin X1 file player, Westminster Labs interconnect cable
Sound like you may have popped a tooth on one of the gears. Worst case it's got a timing issue. Pull it apart to know for sure.
I was able to make multiple repairs to my ice maker during a two year period then it finally came down to replacing it. -
My icemaker had that same type of sound/issue. I was able to pull the front cover off and their were a couple of plastic gears underneath the cover. One was split. I ordered a new gear from Sears Parts Direct, installed it, and all was well.DKG999
Music System: Magnepan 1.6QR, SVS SB12+, ARC pre, Parasound HCA1500 vertically bi-amped, Jolida CDP, Pro-Ject RM5.1SE TT, Pro-Ject TubeBox SE phono pre, SBT, PS Audio DLIII DAC -
http://www.repairclinic.com/ once you find the problem. I too think gear got stripped a little.
Well, got home this evening after a long day of driving folks around to their various appointments and lo and behold the noise had stopped and when I dropped the lever down it started to make ice again! So it would appear that all is now well but just in case I am scoping out prices of a new ice maker
Thanks for all the thoughts!Computer room Hegeman 1 SpeakersM&K VX-80 subKenwood DP-7010Cambridge Audio CXC Transport Rega DACPrimaLuna Prologue Four AmpAric Audio Tube PreampGarage Jennings Research SquareCustom tube preampCrown XLS-1000Denon DCD-1500II Modded MSB Link DAC
