Question about optimizing performance.....
shawn474
shawn474 Posts: 3,052
edited January 2014 in The Clubhouse
As you can see from my signature, I just recently upgraded my system to lsi 9's as fronts, lsi c center and lsi fx's as rears. I HAD rt55's in front, cs400 center and fx300i's as rears. I am running the pioneer elite as a pre and the b&k av5000 as my amp. My question related to optimizing performance. I am wondering if the amp is 4 oh. Stable first of all. Secondly, would it be better for performance to bigamous the 9'sa nod run the center with the open channel. Then run the surrounds off the avr. Right now I have one channel on the amp assigned to each speaker. Any suggestions on how to get better performance? If the amp isn't 4 ohm stable am I harming anything or should I upgrade?
As always, thanks I and acne for any suggestions you have.
Take care,
Shawn
Shawn
AVR: Marantz SR-5011
Center Channel: Polk LsiM706c
Front: Polk LsiM703
Rear: LSI fx
Subwoofer: SVS 20-39pci
DVD Player: Sony PS4
Post edited by shawn474 on
  • shawn474
    edited January 2014
    Looks like my amp isn't 4 ohm stable according to this chart. http://www.bkcomp.com/fileadmin/content/bk_support/FAQ/Previous%20Amp%20Specs.pdf
    How much harm am I doing running this setup with my amp?
    Shawn
    Shawn
    Front: Polk LsiM703
    Rear: LSI fx
  • disneyjoe7
    disneyjoe7 Posts: 11,435
    edited January 2014
    Bummer :sad:
    Speakers
    Carver Amazing Fronts
    CS400i Center
    RT800i's Rears
    Sub Paradigm Servo 15
    Electronics
    Conrad Johnson PV-5 pre-amp
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
    Sony CX400 CD changer
    Panasonic 42-PX60U Plasma
    WMC Win7 32bit HD DVR
  • shawn474
    edited January 2014
    disneyjoe7 wrote: »
    Bummer :sad:
    Don't be sad; it's really my own fault. Should have researched before doing it. Now I will just have to upgrade the amp as well.
    Shawn
    Front: Polk LsiM703
    Rear: LSI fx
  • disneyjoe7
    edited January 2014
    I'm not sad, you're right sad for you.... :wick:
    Speakers
    CS400i Center
    RT800i's Rears
    Electronics
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
  • polkfarmboy
    polkfarmboy Posts: 5,703
    edited January 2014
    You are not doing any harm unless your really cranking that amp. Emotiva amps are 4ohm stable
    heiney9 Posts: 25,408
    edited January 2014
    B & K are pretty stout amps. I think you'll be fine unless you really get on it.
  • shawn474
    edited January 2014
    Thats all good to know! Might keep using it then and use as an excuse to eventually upgrade the amp. Looking at the sherbourn in the flea market - its local to me and hoping to hear back from the seller.
    Shawn
    Front: Polk LsiM703
    Rear: LSI fx
  • cfrizz
    cfrizz Posts: 13,415
    edited January 2014
  • steveinaz
    steveinaz Posts: 19,545
    edited January 2014
    heiney9 wrote: »
    Exactly.
  • shawn474
    edited January 2014
    Been monitoring the heat of the amp (it typically runs pretty warm). Not anything so far that seems to be running hotter so I am not really worried about it...........yet. Thanks again all.
    Shawn
    Front: Polk LsiM703
    Rear: LSI fx
    tonyb Posts: 33,068
    edited January 2014
    Well, that particular model of B&k amps is on the light side. If you like the sound, then hit up the bigger more current throwing monsters in the B&k line up. After that, experiment with different cables, maybe have Trey do the crossovers, or even take a look at the LSIM's which are easier to drive than the 9's.
    Also, source components can go along way in improving performance, that's obvious. But I can tell you I have the same receiver as you and it's a huge limiting factor, particularly the pre amp section.
  • shawn474
    edited January 2014
    tonyb wrote: »
    I would love to be able to do all those things. Right now all the pocket change went into upgrading the speakers. Have my eye on a few amp that will drive them better but content for now. Will sell some gear and see if I can fund a new amp or better pre amp, etc.
    Shawn
    Front: Polk LsiM703
    Rear: LSI fx
