Monitor 5 Crossover Questions
OutcastColt
OutcastColt Posts: 10
edited February 2014 in Vintage Speakers
Hello all,
I am new to the group and have just been bitten by the vintage bug. I have come across some Polk RT 7 (still looking for another driver) and Monitor 5's that I was able to get my hands on. All being pushed by an HK 330B receiver that I picked up at goodwill.
My question is I planed on rebuilding the crossovers in the monitor 5's, but after pulling it apart the crossover does not resemble any of the ones that I have seen posted.
After reading through several of the threads I see that every one is using 630v caps and the ones in my crossover are 50v ksc's. The values match the schematics so is the voltage something I should be worried about.
My plan is to replace with ClarityCaps and I am looking for suggestions on what to replace for the resistor with. I see that H9 used mills in his crossover rebuild but that is the only one that I have found that specified.
I do have the SL2000's and was planning on changing out the 2ohm resister with a 4.5ohm. I have read that it helps with the +6db spike at 12 or 13K cant remember.
Any and all feedback would be appreciated.
Coy
HK 330B
Polk RT7
Polk Monitor 5
Post edited by OutcastColt on
  • skrol
    skrol Posts: 3,437
    edited January 2014
    The values look correct. The construction looks more modern than my Monitor 5B which used the SL2000 and were made in 1984. Perhaps they are a late run of the 5B or the XO is from a Monitor 5 Series II (1990).
    Swap the SL2000 for the RDO194 and you will be very pleased with the highs. Also, get rid of the poly-switch (PS-1).
    Stan
    Main 2ch:
    HT:
    Other stuff:
  • OutcastColt
    edited January 2014
    Skrol,
    Thanks for the reply, I am thinking they are around 1988 or so. From the schematics they are the 5rev and I just replaced the sl2000 for $40. When I go it the sl2000 where damaged, so I will probably hold of on the rdo-194's at least until I recap the hk 330b which will be in about 4 months or less if I can get my self away from listening to system for about a week or two.
    Thanks for the info about the poly-switch I will punt that in the rebuild of the crossover.
    HK 330B
    Polk RT7
    Polk Monitor 5
    F1nut Posts: 51,700
    edited January 2014
    As long as the voltage is the same or higher, all is good.
    Everyone is not using 630V caps. In fact, there's no need for a 630V cap, just makes the size bigger. Try Sonicap instead, comes in 200V, so much easier to fit on the boards and more importantly, sounds great.
    For the resistors, Mills 12 watt are an excellent choice, IMO.
    That'll kill the spike, it'll kill the all high frequencies too. I read that you just replaced the SL2000's, which is unfortunate as the RD0194-1 is vastly superior. Put those SL2000's back on eBay and grab the RD0's.
  • westmassguy
    westmassguy Posts: 6,850
    edited January 2014
    This^^^^^^^^^
    You should also consider the "TL" Modification, which allows use of the RDO-198-1. As good as the 194s are, the 198s are even better. See "schematic_m5b_sl3000mod".
    Home Theater/2 Channel:
    dhsspeakerservice.com/
  • soundfreak1
    soundfreak1 Posts: 3,414
    edited January 2014
    I used the SA clairity cap (600 VOLT) in my 5jr+'s they sound fantastic.l alsi used the 250 volt esa's in my 12c's ( smaller) also fantastic results.mills resistore work great as well.pull the poly cap and use the rdo 194 and u will be quite surprized.
    Main Rig:
    Nakamichi EC100 Active xover
    MIT exp 1 ic's
    Perreaux SA33 class A preamp
    AQ kingcobra ic's
    OPPO 83 CDP
    ADS L1590/2 Biamped
    MIT exps2 speaker cable
  • OutcastColt
    edited January 2014
    All thanks for the responses,
    F1nut, thanks for the info on the caps. Whats the cost of the RDO-194's and 198's?
    Whats your guys take on solid copper speaker wire to replace what s in the speakers?
    Coy
    HK 330B
    Polk RT7
    Polk Monitor 5
  • Schurkey
    Schurkey Posts: 2,122
    edited January 2014
    About $110 a pair, sales tax included, free shipping for Club Polk members. Call customer service to order.
    Define "solid copper". Do you mean single-conductor copper wire as opposed to multi-stranded-conductor copper wire? Or do you mean solid copper as opposed to silver-plated copper, or copper-plated aluminum?
    "I" would leave it alone, gains will be minimal and expense will be considerable.
  • skrol
    skrol Posts: 3,437
    edited January 2014
    Do the RDO tweeters, capacitor and resistor upgrades and you will be amazed. I used Clarity Cap PX and the difference was incredible.
    Stan
    Main 2ch:
    HT:
    Other stuff:
  • OutcastColt
    edited January 2014
    Schurkey,
    Single-conductor copper wire, I was gong to use strands of Category 6 network cable which I have plenty of. It is typically 23awg and solid copper core. With my 330b I am only pushing about 25 watts so I dont see the 23awg as huge deal, but again I am no expert.
    I guess with all the sugestions I am going to have to bite the bullet and by the rdo's, should I do the 194 or 198's?
    HK 330B
    Polk RT7
    Polk Monitor 5
  • TennMan
    TennMan Posts: 1,267
    edited January 2014
    Schurkey,
    If that is your only choices I think you would be better off sticking with the factory wiring.
    F1nut Posts: 51,700
    edited January 2014
    westmassguy makes an excellent suggestion, TL your speakers and use the RD0198-1 tweeter.
    As for the cabinet wire, why would you replace 16 gauge with 23 gauge?
  • OutcastColt
    edited January 2014
    F1nut, I figured that the solid copper core would be better then the factory wire, but wasn't sure. From past experience I know that solid copper core although smaller typically would have a lower resistance then stranded cable (if true copper), but again with the wattage probably would be minimal.
    I am new to audio so trying to absorb as much as I can. I have dealt with electronics, air traffic control radars, communications networks, but I am a noob in audio but I am fascinated by it. So please disregard my ignorance, but I prefer to ask questions when I am not sure about something or do not have the data to back it up. I do search but tend t o have a habit of seeing squirrels and tend to loose my train of thought (SLAMMING MY HEAD ON THE DESK)......LOL $hit squirrel, vodka gotta go need a refill.......
    But all thanks for all the suggestions
    HK 330B
    Polk RT7
    Polk Monitor 5
    pitdogg2 Posts: 26,961
    edited January 2014
    Schurkey,
    Cat 6 data wire can degrade the sound as some of it has a higher capacitance and can roll off highs or lows....been there done that. Stick with wire that is in there.
  • OutcastColt
    edited January 2014
    pitdogg2,
    Thanks for the info I will stay with the wire that is in there.
    Coy
    HK 330B
    Polk RT7
    Polk Monitor 5
  • Weber
    Weber Posts: 6
    edited January 2014
    I would look for a older set of crossovers and rebuild them.That pcb seams to crowed for any bigger caps.Use some mill spec 18 awg silver plated ofc wire to re-wire them.They will be so open and airy you will think they disappeared.
  • Zentish
    Zentish Posts: 127
    What does "TL your speaker" mean?
    Receiver: ONKYO TX-NR929 7.1 AVR 130wpc
    Mains: 2x Polk RTA 8TL's
    Center: Polk CS245i
    Surrounds: 2x Klipsch RS-41ii (because they fit perfectly over the door and window)
    Rear Surr: 2x Polk M4a '90
    Subwoofer: Speakerlab DAS-SW dual-voice-coil 10" '88 30Hz-150Hz
    Subwoofer Amp: ONKYO A-8019 AMP '85 100wpc
    Display: Samsung 55" UNC55-8000 3D LED
    Console: Xbox360
    DVR: custom MythTV rig w/ 3 tuners OTA
    Zone2: 2x Polk M5b '87
  • StantonZ
    StantonZ Posts: 452
    I'm another happy customer with the RDO-194 replacement; I also used SoniCaps and Mills resistor on the XO upgrade (I second F1's comment about NOT doing that resistor change). However, DO replace the PolySwitch with a 0.5 Ohm resistor (or so): those PS wreck your high-end.
    (2) Polk RC80i (Top Middle)
    Polk CS300 center channel
  • TennMan
    Zentish wrote: »
    TLing your speakers refers to modifying your crossover to make them compatible with the Polk RDO-198 Tri-Laminate tweeters. In some cases, as with my SDA 2B and CRS+, it only requires adding an additional capacitor to the crossover.
  • mikemokr
    mikemokr Posts: 150
    TennMan wrote: »
    I've searched and deduced some of the answer to this but what in a nutshell are the requirements for a speaker to be TL'able? SL2000 tweeter? SL1000? I assume not the Monitor 4 with SL1500 because no upgrade path for that tweeter. Assuming a tweeter that can be swapped out for the 198, are only certain stock xo's compatible for some reason?
    I'm interested in this mainly for vintage Monitors. Currently I specifically am wondering if I could TL my Monitor 5JRs, circa 1988 with SL2000. Actually the latest iteration of my thinking could involve a TL mod for just one of the 5JRs, for use as a center with CRS+ 4.1TL and something else TL'd in the rear.
    Main HT (family room): Polk Monitor 7 (1987-original owner) (L/R) / CSi40 (C) / RTi38 (SL/SR) / SVS 20-39PC (sub), Outlaw 975 pre/pro / Outlaw 7075 amp, Oppo BDP-93 Blu-ray, LG 42LM5800 teevee
    2ch (family room): CRS+ (1987), Outlaw 1050 AVR, Denon DCM-420 CD
    Kitchen satellite 2ch: Polk M3II, Topping TP-20 Tripath amp fed from 975 rec line out
    Home office: Model 5 (1978-Danish Peerless), Lepai 2020A+ Tripath amp fed by laptop dock
    Awaiting assignment: PSW202 (NIB) to be wired inline in home office rig; Monitor 5JR (1988), Model 4 (1983-US Peerless)
  • TennMan
    mikemokr wrote: »
    I'm not the best person to answer your question about which speakers have crossovers that can be TLed. My experience with vintage Polks is limited to the ones that I have owned. SDA 2B, CRS+ and monitor 10B. In general, I believe the speakers that would have factory installed crossovers that are compatible with the RDO-198 tweeter are the ones that came from the factory with the SL3000 (and maybe the SL2500). For specific models that can be TLed I'm sure someone with more knowledge than me will chime in.
  • mikemokr
    mikemokr Posts: 150
    To clarify, I'm looking for characteristics that allow a model to be TL'd, whether simply via a drop-in 198 (like from an SL3000) or with xo mods plus the 198. For one specific question, is anything with an SL2000 TL'able with xo mod or is that not possible in some cases for some reason? Don't mean to hijack the thread but I don't think this strays too far off topic.
  • westmassguy
    mikemokr wrote: »
    You'll need to identify exactly which 5Jr you have, as there were several versions. Check the component values of your crossover against one of the schematics here: http://www.polkaudio.com/forums/showthread.php?38755-POLK-AUDIO-Speaker-Wiring-Schematics-amp-More-ALL-MODELS-except-SDA
    Sanctioned TL Mods are usually denoted as SL3000 or TL. That doesn't mean your Monitors can't be modified. Some TL mods are simple, where a New Shunt Capacitor is added, while others require changing Capacitor values and Shunt Inductors.
  • mikemokr
    mikemokr Posts: 150
    I will do that WMG but I am wondering if there are any general rules of thumb. Am I right to surmise from your reply that having an SL2000 doesn't in and of itself make a Monitor eligible for a TL mod, whether sanctioned or not? Are there any automatic show-stoppers in the crossovers?
    My questions are geared in part to potential future purchases, especially since numerous Monitor models with SL2000s seem to be fairly common. But I'm also thinking of my Monitor 7s (1987, SL2000) as when the time comes to mod those I'd like to TL them if I can.
  • westmassguy
    There is no general rule. Each must be investigated individually. Your Monitor 7s with SL2000 tweeters should have a crossover nearly identical to the 5B. So, while there's no Monitor 7 SL3000 Mod, the 5B SL3000 Mod will work. The Revision 2 schematics were the last versions of the Monitors and came with SL2500 Tweeters. Many of the Cap and Inductors values are different. I would not use those as a guide.
  • Hawnfi
    Hawnfi Posts: 1
    Aloha all!
    I'm just an old carpenter that loves good sound. I'm new to the Polk world and see a pair of M5s on Craig's List asking $150. I'm not about to attempt a recap so is there someplace (or someone) who I could send the CO to bring them up to standard?
    I'm setting them in a typically small condo room with a lot of glass walls and feeding them through a Luxman 40 wpc. Mostly classical listening.
    Any advice?
  • Jimbo18
    Jimbo18 Posts: 2,348
    The post above you is from westmassguy, who is one of the people on here that will do the recapping.
    Prices in Hawaii are probably different, but $150 seems a bit high for M5s, unless they are scarce there and in fantastic shape. Also, be aware there are a bunch of different versions of M5's.
  • boston1450
    boston1450 Posts: 7,758
    +1 on the above. Depending on what you have for 5's & tweeters - you could change out the tweeter for a better "Drop In" replacement from Polk. Then do the crossover upgrade because those 20+ year old Xovers are tired. WMG does outstanding work. I also have the 5a's & plan on doing those. They are a fine speaker. Welcome to the forum
    Randy-Maine
    2ch-RTA15tl crossover upgrade
    by David WMG
    Yamaha cr1000 cr2040
    HT-Yamaha Parasound Acurus
    MIT BJC Cs1000p Polk Rotation
  • gdphoto
    gdphoto Posts: 182
    How do you determine exactly which Monitor 5's you have? Mine only states Monitor 5 on the back with SN's. I noticed 1986 on the XO's.
    Hafler DH220 Power amp Recapped
    Hafler DH110 Preamp Recapped
    Hafler Digital FM Tuner
    Virtue Audio M1 Piano CD Player
    Technics SL-1210-MK5 with an Ortofon Black LVB250 Cartridge
    Polk SDA1c's(Rebuilt XO's by Ben) RDO194 Tweeters
  • gdphoto
    gdphoto Posts: 182
    Also, If I just do a basic XO mod, can I still upgrade to RDO 194'S?
  • skrol
    skrol Posts: 3,437
    edited January 2017
    Based on the year, I'd say Monitor 5B. The 5A ended with 1983 and the Monitor 5 Series 2 started around 1989. Post a pic and we can tell for sure.
    The tweeter choice would depend on the XO mod. If you simply upgrade XO components then go with the RDO194. If you do the TL mod then go with the RDO198.
    Stan
    Main 2ch:
    HT:
    Other stuff:
