Point 2 Point Crossovers...
Toolfan66
Doing a point 2 point crossovers is a lot of fun, it takes a lot of time, and you have to pay attention to detail, and most important making sure your connecting everything correctly...
I thought about having Trey do them, I talked to him about them, but I wanted to have fun doing them myself, and it saved me a lot of coin. It's not really that hard once you get started.
Working in a sheet metal/machine shop is a plus as well, I still have some work to do, but I am looking forward to hooking them up.
I am doing my CRS+'s and my 1.2tl's.. I am not going external as I had initially planned, I didn't like how it was going to look, so I'm sticking with internal..
Post edited by Toolfan66 on
I wouldn't bother with PCB's unless it's a mass produced speaker line. Point to point is easy once you have everything orientated."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
I recapped some speakers with PTP wiring-- you guy's ain't kiddin'' you really do have to be focused(at least I did)JC approves....he told me so. (F-1 nut)
When your using Clarity MR's and Dulund Resistors a PCB is worthless IMO, and it's a good learning experience. Also a PCB is like doing paint by numbers.. LOL!!!
George, I have to be very focused as well, especially with the 1.2tl's.. -
I did a pair of CRS+ P2P with wafer board....time consuming but an interesting project.CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint.
My first recap job....Infinity RSIIIa
Before....was an ugly(er) mess! lol
--Gary--
Definitely interested in seeing what you come up with for the CRS+'s.
I'm almost done, this takes time when your anal about it, As many hours as this can take, what Trey charges to build them is spot on, so anyone that might feel his prices are high, try and do it yourself, and you will see he is more then fair, especially when you add the cost in capacitors, inductors, resistors, wire, delrin, custom box, hardware, solder, molex connectors, and I can keep going..
I have about 40 hours + in mine! and I'm sure he is about the same! he might be a little quicker since he has a few under his belt. I should also add, I don't think anyone should try it if they haven't done cross over upgrades with just the boards, it can be tedious to say the least, but it is a lot of fun if you just take your time and follow the schematics.. -
Yeah, some of the mods I can do faster, my Fortress line is fairly stream lined. When I get into the Monastery line where most of it is custom and one off builds the labor is sometimes daunting. When you factor in research, planning, etc it sometimes can get into the 80 hour mark or longer..
I look forward to seeing yours when done!
- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
I also enjoy building P2P crossovers, especially since you can make them fit where you need to.
My favorite is still this one...- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
I would have to agree Trey. They are most beautimus.HT: LSI15, LSIC, LSIFX, Emo XPA-3:biggrin: Onkyo TXNR809, Sony BDP-S500, PannyDMP-BDT320, MIT S1 SC. Mit 73842dlp
2ch: SDA-SRS 2.3 Fully modded. BAT VK500 w/batpak, BAT VK5I, Essence HDACC. -
Thank you
