BIC F12 with sub iso pad = quality AND quantity
felipe
felipe Posts: 423
Initially, I had my bic f12 placed in its position w/o a sub iso pad...sounded pretty badass! Then, just to experiment, I used my sub riser/pad that I had for my psw110 for my f12. SURPRISE!! Not only did the bass quality increase (clarity and tightness) but the sound output jumped! I had to decrease the level on the sub...it was already set low to begin with.
If you want to eliminate the boominess and clean up the sound of your sub, a sub riser/Iso pad WILL work :-). Thanks for looking;-).
My Setup: Denon AVR X3600h, Polk Signature S50 Fronts w/ S30 Center and S15 Rears, LG UBK90 4K Player, TCL 6-Series 65”4k TV
Post edited by felipe on
  • aboroth00
    aboroth00 Posts: 1,107
    edited December 2013
    Hey! Good to hear buddy and glad to see you're enjoying your new sub! We get wrapped up in getting the best out of everything to enjoy what we have sometimes.
    Raising your sub off the floor is essentially raising it away from a boundary so you won't get as much boundary reinforcement and the sub will react differently with the room. I'm also using an isopad in my setup with good results even though the floor is tile over concrete! I wonder what'd it'd do with a wood floor.
    2Ch Tube Audio Convert
  • Mikey081057
    Mikey081057 Posts: 7,127
    I use subdudes under all of my subs... they make a difference for sure, and are a must on wood floors
    Garage | Polk Monitor 5B's
  • felipe
    felipe Posts: 423
    Absolutely:-). When I used it with my psw110 it had the same effect...just not as profound. Mine is a diy sub isopad...painted MDF with 2layers of EVA foam gym mats cut to size. Cheap yet quite effective;-).
  • mufsoman
    mufsoman Posts: 636
    My theater is in the basement which is carpet over concrete. So will a sub isolation pad help with that or are these more for apartments/suspended floors? Thanks
    Sony 83A80L TV and Roku Ultra
    Denon 3800
    Parasound HCA-2205A
    SVS Prime towers, center channel and bookshelfs (side surrounds)
    Atmos: Mirage Nanosats x 4
    Turbo MFW-15 x 2
    Panasonic DP-UB820
    APC H15
    Morrow MA4 & AQ Cobra IC's, AQ Midnight speaker cables
  • felipe
    felipe Posts: 423
    mufsoman wrote: »
    Sub isolation pads/risers can be used for any situation. Theres a more noticeable difference when they are used on suspended or wooden floors. My set up is on carpet over concrete slab....I notice a difference. My bass now is cleaner,more defined, and in some ways more powerful b/c the energy isn't transfered to the floor...I feel it more in my chest now when the bass hits;-). Take it from me...it helps.
  • felipe
    felipe Posts: 423
    A lil update...I setup my psw110 at the folks house, and I used the Iso pad from my bic f12 with it (it was originally made for the 110 anyways). So, that left me to make a new one for my f12. Using what I had at home, I used the top portion of a dinner tray table ( made of rubberwood) and painted it in the same fashion as my prev. pad, found some 2" square rubber furniture feet and a large extra thick mouse pad that I cut into pieces to fit the inner part of the feet. Then, assembled the cut pieces of mouse pad and furniture feet into legs...or " stumps" as I call them. Lastly, put it all together. I'll post pics when I get the chance. I am surprised that my f12 with THIS iso pad sounds sooooo much more tight and defined! It could be the design...or the height difference compared to the other Iso pad...whatever it is, I'm glad I built it. I guess b/c of/its design its not really a "pad" but more of a riser...or in my case, a "low-riser" lol.
  • felipe
    felipe Posts: 423
    Ya I was planning on doing that..as soon as I have the time :-)..and when I finish all of the tinkering with the current design ;-). Thanks.
  • snake1
    snake1 Posts: 567
    felipe wrote: »
    I'd be interested as well!
    AVR - Onkyo NR809
    500gb HD for MP3 and FLAC files
    Amp - Parasound 2250 - FOR SALE BTW!! PM me if interested!
    Mains - Polk RTi12 towers
    Center - CSi5
    Surround - FXiA6's
    Sub - psw505
    Movies and games - PS3
    TV - Toshiba 52" HD
    Every vehicle has one good nuetral drop in it
  • felipe
    felipe Posts: 423
    Sorry all, I tried to upload the pics, but I cant because the img file is too large. ill try to retake or resize so I can post them.
