Parasound HCA1000A
Terrax
Terrax Posts: 483
edited July 2004 in Flea Market
For sell, one Parasound HCA1000A Amp. 7/10 if not 8/10 on the Audiogon scale. One small 1/8th" scratch on lower right of faceplate. Do not have original box, do have Manual.
$250.00, Shipping Included.
Will double box and provide excellent packing.
terrax@wnclink.com
Specs for Amp:
Continuous Power Output - Stereo: 125 watts RMS x 2, 20 Hz - 20 kHz, 8 ohms, both channels driven; 200 watts RMS x 2, 20 Hz - 20 kHz, 4 ohms, both channels driven
Continuous Power Output - Mono: 400 watts RMS, 20 Hz - 20 kHz, 8 ohms
Current Capacity: 45 amperes peak per channel
Slew Rate: >130 V/µsecond
Power Bandwith: 5 Hz - 100 kHz, +0/-3 dB at 1 watt
Total Harmonic Distortion: < 0.03% at full power; < 0.01 % typical levels
IM Distortion: < 0.03 %
TIM: unmeasurable
Dynamic Headroom: > 1.5 dB
Interchannel Crosstalk: > 80 dB at 1 kHz; > 60 dB at 20 kHz
Input Sensitivity: 1 V for 28.28 V, THX Reference Level; 1.1 V for full output
Input Impedance: 33 k ohms
S/N Ratio: > 116 dB, full power; > 96 dB, THX Reference Level
Damping Factor: > 800 at 20 Hz
Power Consumption: 500 watts
Dimensions: w 17 1/4" x h 3 1/2" x d 13 1/4", h 4 1/8" with feet
Net Weight: 22 lb
Features of amp:
Circuitry designed by John Curl
THX Ultra-certified
Direct Coupled -- no capacitors or inductors in signal path
Input stage uses hand matched complementary JFETs
12 beta-matched 15 amp, 50 MHz bipolar output transistors
785 VA Toroid power transformer with independent secondary windings for each channel, 40,000 µF power supply filter capacitance
Independent power supplies for each channel
DC Servo and relay protection circuits
High bias Class A/AB operation
AC present, standby/normal, current overload indicators
Tiffany-style RCA input jacks, loop output jacks
12 volt DC automatic turn-on circuitry
Gold-plated 5 way speaker binding posts
Custom designed removable IEC AC cord
Rear mounted gain controls; ground lift switch
2 rack space height front panel
Rack mounting adapter available
Post edited by Terrax on
  • Mike682
    Mike682 Posts: 2,074
    edited July 2004
    I saw that gmorris was looking for one....check the electronics thread..
    ***This reply is not meant to put anyone "in line"***
    Mike
    Receiver: harmankardon AVR235
    Mains: polk R30
    Center: polk CSi3
    Rear Surrounds: polk R20
    Subwoofer: polk PSW404
    DVD: Panasonic DVD-S29
  • steveinaz
    steveinaz Posts: 19,546
    edited July 2004
    Great amp, great price and Terry is a top-notch buyer/seller.
  • dorokusai
    dorokusai Posts: 25,625
    edited July 2004
    I second that comment from Steve :D
  • Terrax
    Terrax Posts: 483
    edited July 2004
    Bumper, Thumper! ;)
  • Mothra
    Mothra Posts: 20
    edited July 2004
    I may be interested Terrax...can you provide any current pics of the amp?
    Thanks!
  • Terrax
    Terrax Posts: 483
    edited July 2004
    I would glad to post pics, but I do not have access to a digital camera. I borrowed one a couple of weeks ago to get some pics up at the time. If I can get access to one, I most certainly will.
    BTW, welcome to the forum, Mothra
  • Mothra
    Mothra Posts: 20
    edited July 2004
    Thanks for the kind welcome Terrax. As you can see, I registered long ago, but then stopped coming to the site, as other hobbies took priority.
    Things change, so I've been lurking again for awhile. Your amp finally got me to post. Don't you feel special!
    Regards!
  • Terrax
    Terrax Posts: 483
    edited July 2004
    Aye, special indeed. :D And here I thought I had the Lurker Crown all wrapped up....... ;)
    Well, I quess welcome back, would be a better way of putting it.
  • Terrax
    Terrax Posts: 483
    edited July 2004
    Need to move this. Price dropped to $250.00, Shipping Included.
    terrax@wnclink.com
  • Terrax
    Terrax Posts: 483
    edited July 2004
    Just so everyone understands, the price has been dropped to $250.00 on this, shipping included.
    Thats 200 w/c into 4ohms and 400 watts bridged. Would make one helluva passive sub amp. Or, as I once ran it, a killer center channel amp.
  • ezc
    ezc Posts: 426
    edited July 2004
    Terrax,
    Is the amp still avail? Let me know.
    Ace
  • ihammerhands
    ihammerhands Posts: 9
    edited July 2004
    I am looking for an amp to replace my Proton AA-1150 and was steered to this ad. Please let me know.
    Millard
  • Terrax
    Terrax Posts: 483
    edited July 2004
    Thanks for the interest. Someone has indicated they would like to get the amp, but won't know until this weekend. If they do not want it, It will still be up for grabs.
    Thanks,
    Terry
