which way connecting a dac for best sound quality
starstern
quality of the clocking is greatly associated with power supply and ground plane currents, not to mention internal em/rfi.:
,spdif cable ,
fire wire to usb,
halide design bridge ,
thunderbolt,
OR5,
MCRU linear power supply.
bottom line am not tech but just practical terms step by step ,how do i set up my dac to my laptop or CDP for up-most results in sound quality ?
,spdif cable ,
fire wire to usb,
thunderbolt,
OR5,
Post edited by starstern on
Attach the output of the CDP or laptop to the input of the DAC, and use a good cable.Lumin X1 file player, Westminster Labs interconnect cable
Three 20 amp circuits. -
http://www.head-fi.org/t/527442/optical-toslink-vs-usb-which-connection-is-better-to-connect-a-dac
seems talking about having spdif metal halide design bridge as the best connection ?? -
What equipment are you using because there is no point in us recomending cables that may cost more than your dac. The best connection is a direct connection for theoretical purposes
polkfarmboy wrote: »What equipment are you using because there is no point in us recomending cables that may cost more than your dac. The best connection is a direct connection for theoretical purposes
Toshiba high end laptop
trheorem 720 dac amp
aiwaq nsx 3900 dsp for speakers
