Onkyo TX-SR705 issues
Phish56466
Anyone else using a TX-SRx05 series AVR? Have you had anything odd happen when up converting the video? Mine has split the signal(like it's loosing a sync signal) when going from composite to component or composite/component to HDMI. I might be overlooking something in the menu's but I doubt it. Any thoughts or ideas guys? This is a pain in the arse.
Monitor 12's-RDO's and XO's done!
Onkyo TX-SR705 AVR
Adcom GFA-555 for power(being reborn, as I can afford it)
Onkyo DX-C730 changer
Onkyo CP-1057F table W/Grado cartridge
CS300 center
M4's for rears
LG 47" LCD
ROKU streaming gizmo
Onkyo TX-SR705 AVR
CS300 center
M4's for rears
LG 47" LCD
Post edited by Phish56466 on
The x05 series is widely know for failing the Hdmi board due to heat issues. I would have it checked out.Main Surround -
Den - Rotel RSP-1068 / Threshold CAS-2 / Boston VR-M60 / BDP-05FD -
Another ODD thing I've observed is that when it does this, all I have to do is switch sources and then back and it'll clear up for a while. I had KIND of thought that PCB was the issue. For a LONG LONG time I drove my M12's(at times quite hard) with the amps in my 705, so heat makes a LOT of sense. I'm guessing a new pcb would require some type of calibration or alignment procedure to get it into spec(I have yet to find a service manual for it-hifi engine has the user manual though), any ideas? Or do you think it's possible to order a new one and drop it in?Monitor 12's-RDO's and XO's done!
Onkyo TX-SR705 AVR
CS300 center
M4's for rears
LG 47" LCD
ROKU streaming gizmo -
It is my understanding that onkyo only sells parts to authorised service centers.Oh, Listen here mister. We got no way of understandin' this world. But we got as much sense of this bird flyin in the sky. Now there is a lot that bird don't know, but it don't change the fact that the world is happening to him all the same. What I am tryin to say is, is that the course of your life, well its changing, and you don't even see it- Forest Bondurant
I have a 705 that loses settings when the power goes out. I ended up replacing it with a 717 as it made more sense than to pay to and from shipping.Oh, Listen here mister. We got no way of understandin' this world. But we got as much sense of this bird flyin in the sky. Now there is a lot that bird don't know, but it don't change the fact that the world is happening to him all the same. What I am tryin to say is, is that the course of your life, well its changing, and you don't even see it- Forest Bondurant
Shipping that bad? IF I do anything it'll be an upgrade to a pre/pro and a 5 channel amp to drive the HT stuff. HOPING next year will be a little more kind to my bank account.Monitor 12's-RDO's and XO's done!
Onkyo TX-SR705 AVR
CS300 center
M4's for rears
LG 47" LCD
