Preamp Tube Question
Polkitup2
Polkitup2 Posts: 1,640
edited December 2013 in 2 Channel Audio
I just received the Psvane tubes in the photo from Grant Fidelity. I know very little about tubes and was wondering if one of the tubes has an issue. In the photo one tube has a hazy top while the other is shiny metallic. Is the hazy tube ok to use or is it a defect or something?
Post edited by Polkitup2 on
  • Polkitup2
    My research indicates that the white getter is due to a vacuum leak.
  • george daniel
    george daniel Posts: 12,096
    while it does appear very suspicous,,have you tried it or tested it?
  • Phasewolf
    Phasewolf Posts: 514
    Personally the only time I have seen a tube like that was when it lost part or all of it's vacuum but send the pic to where you ordered them from and check them on a tube checker and see where it's at.
    Absolute corruption empowers absolutely.
    Lg 55LW5600 TV
    Onkyo PR-SC 5508
    Legacy Audio Focus SE
    Legacy Audio Silverscreen HD center
    Polk F/X500i Rears
    Parasound HCA-3500
    Sunfire Grand Cinema
    Behringer iNUKE NU6000DSP
    Pair of CraigSUB SS-18.1
  • Msabot1
    Msabot1 Posts: 2,098
    Don't bother to run a test....it's toast...send it back for a replacement. Did it arrive in that condition?
    heiney9 Posts: 25,408
    All indications are it's lost it's vacuum. Anytime the getter material is milky whitish color means the tube has no vacuum and it can not be used. Send it back for a replacement.
  • Polkitup2
    Thanks Guys, I am asking for a refund, going to go with Gold Lions instead, not sure I want to wait another 3 weeks to get the psvanes from china.
