Phase inverting pre-amp
heiney9
heiney9 Posts: 25,396
edited December 2013 in Electronics
My new pre amp is phase inverting and I have SDA's. Do I need to swap the pos and neg speaker terminals? I can't remember the proper procedure.
Post edited by heiney9 on
  • FTGV
    FTGV Posts: 3,650
    Yes swap the phase on the speakers.However the audibility of absolute phase is debatable.
    Thanks Fred, I was more concerned with the SDA's and making sure they are getting the proper signal to function properly.
  • FTGV
    FTGV Posts: 3,650
    Oh missed your running SDA's part.In that case I would'nt reverse them unless you have one of the isolation transformers.
  • drumminman
    drumminman Posts: 3,396
    My linestage also reverses phase. Best suggestion is to try it both ways to hear which sounds best. IIRC I reversed mine at the speaker and the imaging/clarity/tone was audibly better. I am running a dreadnought, though I wired them the same before the dreadnought without issue.
    SCompRacer Posts: 9,079
    This came up the other day prefixed with Running Cary pre by kroc321.
    http://www.polkaudio.com/forums/showthread.php?155589-Running-Cary-Pre-with-inverted-ouptut-with-SDA-CRS&highlight=phase+pre+amp
    My ModWright pre inverted phase and I couldn't tell a difference reversing speaker cables on my ESL's.
  • aboroth00
    aboroth00 Posts: 1,106
    For most people, absolute phase doesn't make a difference. My rogue 66 with just unbalanced connections inverted phase and I flipped the pos and neg and didn't hear a difference, but YMMV.
    2Ch Tube Audio Convert
  • polkfarmboy
    polkfarmboy Posts: 5,703
    The ps audio perfectwave lets you invert the phase if your in the market for one
  • zingo
    zingo Posts: 11,258
    aboroth00 wrote: »
    The big caution is with SDA speakers, that flipping the speaker outputs can damage the speakers and/or the amp.
  • FTGV
    FTGV Posts: 3,650
    zingo wrote: »
    Yes with common ground.An exception would be if using one of the purpose built isolation transformers and a non common ground amp.Polarity could then be swapped with out issue.
    As for preserving absolute polarity I have never found it to be a significant factor.
  • megasat16
    megasat16 Posts: 3,521
    FTGV wrote: »
    It's because you don't use the In-phase transformers. :P
    Trying out Different Audio Cables is a Religious Affair. You don't discuss it with anyone. :redface::biggrin:
  • FTGV
    FTGV Posts: 3,650
    Ahhh thats it,the old "INPHASE" transformer trick.
    So if your out of phase, just go to the darn store and get some.....
    Did you hear the one about the two out of phase sound waves of equal amplitude that walk into a bar at the same time?
  • FTGV
    FTGV Posts: 3,650
    The store?Don't they sell it in little baggies on the street corner?
  • FTGV
    FTGV Posts: 3,650
    SCompRacer wrote: »
    did you hear the one about the two out of phase sound waves of equal amplitude that walk into a bar at the same time?
    Lol,and let me guess they knocked each other out.
    I've get her hooked up and am tube rolling and it sounds fantastic as is so I won't be futzing with the speaker polarity.
    Good one Rich and Fred :lol:
  • FTGV
    FTGV Posts: 3,650
    heiney9 wrote: »
    Enjoy.
  • megasat16
    FTGV wrote: »
    I don't know if anyone ever attempted the OUTPHASE transformer trick though.
    SCompRacer wrote: »
    I usually look for someone about my size before I rip a loud one in the store. I always hope he may also rip one about the same loudness at the same time to cancel out all the noises so no one would go noticed what just happened.
    FTGV wrote: »
    All this Phase talk makes me a bit uncomfortable now. I hope Mike didn't read this thread. lol
