Tsi100 surround sound not working?
Greenandwhite23
Greenandwhite23 Posts: 20
edited December 2013 in Speakers
So with my Tsi100s, if I plug them into front then they work just fine but when I try to plug them into surround, no sound comes out. I was wondering if you guys would know what the problem is.
thanks
Post edited by Greenandwhite23 on
  • ken brydson
    ken brydson Posts: 8,980
    What AVR are you running? Source??
    tonyb Posts: 33,065
    Are you playing something with surround sound ? Did you set up the avr ? What is the source and how is it connected ?
  • Greenandwhite23
    Onkyo tx sr313 I was just watching netflix on my ps4
    tonyb Posts: 33,065
    Tell us what you have plugged into where and what your trying to accomplish
  • Greenandwhite23
    Hdmi out to tv
    Game hdmi to ps4
    Tsi100 to surround doesn't work but tsi100 to front b does
    Does that mean I need another pair of speakers for surround to work?
  • rooftop59
    rooftop59 Posts: 8,121
    DO you have the surround speakers turned on in the setup menu? Chances are they are not turned on OR you don't have Dolby digital or something like DD PLII selected. Is there a setup mic with that receiver? That's the easiest way to get started.
    Game Room 5.1.4:
    Bedroom 2.1
    tonyb Posts: 33,065
    In your receiver you have to set up every input you have something connected to. Did you read your manual ?
  • monepolk
    monepolk Posts: 1,154
    Just from the picture that Tonyb posted it looks like you should have speakers plugged into speakers A and surround. Check the manual.
    Nevermind I guess you are using speaker B to test.
  • Greenandwhite23
    My receiver did not come with a setup mic and it doesn't appear to have anywhere to plug them in so how can I get to calibration?
  • Greenandwhite23
    I'm not able to access sp config, sp distance and level cal is it because of this?
    tonyb Posts: 33,065
    No, everything is accessible by the remote too. Do you have a manual ?
  • recoveryone
    recoveryone Posts: 929
    http://www.intl.onkyo.com/downloads/product_info/pdf/tx-sr313_euex_leaflet.pdf
    A quick look over the info, I did not see where a calibration mic is use, but all adjustment are made on the fly via OSD (TV) if using HDMI connection.
  • Greenandwhite23
    Yeah I have a manual but for some reason sp config, sp distance and level cal are all dark and I can't click on them on the menu
  • rooftop59
    Something has to be turned on the access those. Time to consult the dreaded manual :evil:
    Game Room 5.1.4:
    Bedroom 2.1
    tonyb Posts: 33,065
    Because you have something else turned on that eliminates those options. Reset the receiver and start from scratch. Read the manual.....twice, cover to cover so you understand what everything does. Todays receivers are not plug and play like receivers of years ago.
