SDA-2B and Pioneer M-22 30wpc class A amp
hauxon
hauxon Posts: 161
edited December 2013 in Vintage Speakers
I've been thinking about buying a vintage Pioneer M-22 30wpc (solid state) class A amp to run my Polk SDA 2B speakers.
1. Does anyone know if the dual mono design of the amp means it does not have common ground (for the SDA connection cable) ...and if does not have common ground, would I be able to connect a wire between the negative connection of the speakers to have common ground.
2. Will the 30 watts be sufficient power for the SDA-2B speakers? If I remember correctly they are 6 ohm and sensitivity 89db. My feeling is that it will be sufficient for most music. Is there a danger I might damage the speakers by having such a small amp?
Thanks,
Hrannar
SRS 1.2 TL | SDA 2B Studio TL | NAD M51 preamp/dac | DIY SET 300B tube amplifier | Cambridge Audio Azur 851W | Chromecast Audio | RoPieee Roon Raspberry Pi endpoint
Post edited by hauxon on
    F1nut Posts: 52,009
    NO, do not do that!
    You'll either have to test the amp or call Pioneer to see if it is or is not common ground.
    That's really not enough power for those speakers.
  • sda2mike
    sda2mike Posts: 3,131
    yep..NO on both questions..
  • Face
    Face Posts: 14,340
    30 watts of Class A wouldn't sound bad on them, I've tried it, but don't expect much in the way of dynamics.
  • zingo
    zingo Posts: 11,258
    That is a fantastic looking amp though, and I'm sure it sounds great on the right speakers!
    heiney9 Posts: 25,515
    NO, do not do that!
    Face wrote: »
    Really? You are both wrong on how it would sound, but to the OP no on the negative strapping and yes the right 30 wpc class A amp will sound excellent unless you are trying win an SPL contest or trying to fill a very large room.
    F1nut Posts: 52,009
    No, I'm right. I've tried low powered amps on SDA's.....sure they make noise, but they don't make music.
  • Face
    Face Posts: 14,340
    heiney9 wrote: »
    It has nothing to do with maximum SPL, especially since they should be capable of over 100db in his setup, it's about dynamics.
  • bigaltx24
    bigaltx24 Posts: 141
    I've been running my 1Bs on a 6-8 watt single end pentode amp for the last couple of weeks. Will it rattle the windows like my 200 watt Denon? No, but it has a certain finesse and smoothness that is very addictive. I'm getting about a 90db SPL and not pushing the amp that hard, plenty loud for me.
    Denon PMA-900V
    Linn Axis with Grado Red
    Cambridge Azur 650C
    Polk SDA-1BTL
    F1nut Posts: 52,009
    Brock, let me rephrase my previous post as it didn't come out properly. Yes, a 30 wpc class A amp will sound good driving SDA's, but it's not going to give one all that the speakers are capable of.
  • nguyendot
    nguyendot Posts: 3,594
    Wow all the heavy hitters came out in this thread. Was glad to see it :)
    Main Surround -
    We can agree to disagree.
    Face wrote: »
    Never, ever had an issue with dynamics with the Aleph, not once, not even driving LSi's. Is it right for everyone in every situation, no, but to just dismiss it completely is short sighted, IMO.
    BS
    Single ended class A amps, specifically?
    You have an opinion, not a factual certitude that you are right.
    Try the right amp and your eyes will be opened.
    F1nut Posts: 52,009
    You know Brock, I've tried and heard a lot of amps with SDA's. Until feed heavy doses of power they never produce what they are capable of.
  • headrott
    headrott Posts: 5,496
    Gonna have to *overall* agree with Jesse and Mike on this one Brock. I've tried the Aleph 30 on my 2.3TL's and the audio was good, but I was always afraid of running out of ooomph. When I put the VK-200 in place of the Aleph 30, things improved greatly (specifically in the way of dynamics as Mike brought up). The Aleph does produce nice sounding audio, but just not enough ooomph in doing it (IMO). And, I was always afraid of running out of power, causing clipping. If I tried to push the SPL levels to 96, 97, 98 dB's, the Aleph 30 just couldn't go there with the 2.3TL's while the VK-200 will. I want to upgrade to the VK-500 eventually and see what a difference that makes on the 2.3TL's. :smile:
    He doesn't have 2.3TL's, he has 2B's. Atleast you are talking from a perspective of owning and comparing two specific amps rather than making a blanket statement. My point is you can't summarily dismiss an entire class of amps. We do have very little info to go on, in the end based on his use, listening room, listening habits it very well could be it's not enough. For me personally, I have never felt the need for more power, ever, period.
    But that's my experience and that's what I am basing my opinion on, not making a blanket statement that it will NEVER work. I am not saying it will ALWAYS work, either. Nothing more nothing less. If the OP gets very specific about his needs, habits, uses then the recommendation could change. The truth is we don't have enough information and everyone in this thread is making their own assumptions and drawing their own conclusions on outcomes.
    Even you Greg aren't being specific about the environment you used the Aleph in, you are simply saying it won't/didn't work. I have a smallish listening area and can easily reach 100 dB+ if I choose to with zero strain on the amp and all the dynamics one could wish for. If I had a larger listening area and really wanted to push the 1C's, it would eventually run out of juice.
    Have you listened to the Aleph or any other Pass lower powered amp on SDA's in a reasonably sized room?
    So to play devils advocate here.
    You are basically saying he'd be better off with an Emotiva 300 wpc amp than something like a 20-30 watt tube amp or a high quality 30 wpc single ended class A like the Aleph? I have tried to read your posts several ways and the above conclusion is what I keep coming to. If that's your stance, fine, but it seems to go counter to everything you have ever posted.
    pitdogg2 Posts: 27,340
    A little sidetrack her if we may. Brock my new audio mag has the Pass X 60 something or another. They say it 60watts class A before it goes to AB...Are those just rated at the class wattage and go to say 125wpc ab wasn't real clear there...
    here is what is at Pass website
    XA60.5 / Specifications
    Gain 26 (db)
    Power Output 60ch (8 ohm)
    Power Output 120 ch (4 ohm)
    Input Impedance,30 / 20(Kohms)
    Leaves Class A @ 120 pk Watts
    Power Consumption 200 (W)
    Dimensions (W x H x D)
    19 x 7 x 19.2
    Unit Weight 62 (LBS)
    So are these like 300wpc with mondo high current ...just trying to wrap my head around this a little...
  • zingo
    zingo Posts: 11,258
    I agree that a benefit of high power is dynamics and staying out of clipping, but it's also bass response. My SRS 2s will do 20Hz, but not without a lot of power, and that has to be balanced with an amp that sounds good in the highs and mids because they only have single binding posts. Even if you have bi-wire posts on your SDAs, you still can't drive the "bass" separately from the mids due to the passive radiator, so your midwoofer amp would need to sound great regardless of power level. I believe there is a reason why modern self-powered subwoofers have gobs of power, and that's because R&D figured out you need high power to create good, deep bass.
    Just my .02
    txcoastal1 Posts: 13,519
    Pitdog, I have the XA30.5, 30w@8ohm: 60w@4ohm approx 185w in A/B.
    This is more than enough juice for my Usher MD2's which are 4ohm@90db eff., but when I tried to use the Pass on my Dyn's (4ohm@85db eff.) they ran out of gas and dynamics. Then I purchased the Modwright 200w@8ohm: 400w@4ohm match made in heaven top to bottom.
    When I tested my Modwright with the Ushers little change in tonality, but the dynamics of the top and bottom end didn't change much.
    Now in the same note we ran the LSiM 705's (8ohm@88db eff) on a 12watt single ended integrated at LSAF, then had a shoot out w/ the 705's using a 36watt high end integrated and the 12watt maintained better tonality and dynamics including the bottom end.
    I very limited experience with SDA's so I can't comment from experience but w/the SDA 2B's being more efficient than the Usher MD2's I can't see why they wouldn't run effectively on 30watts class A.
    Just my .02
    Just what I thought, the rated output is just class A with a bunch of headroom so to speak. Until I read the article I thought they stayed in just Class A :lol:
    I completely understand that the Pioneer is no PASS audio and maybe it doesn't have near the headroom and maybe is not common ground.
    F1nut Posts: 52,009
    heiney9 wrote: »
    I have spoken with Greg about his experiences, but I have no direct experience with your amp. However, I do have experience with the Cary 805's, which at 50wpc are the recommemnded minimum for your 1C's or my 2.3TL's. While they had detail and delicacy in spades there just wasn't enough muscle for that big, powerful sound that SDA's are capable of.
    Have you tried any of the high powered Pass amps on your 1C's?
    You know better than that. I didn't think it was necessary, but I guess I should have said, Until feed heavy doses of quality power they never produce what they are capable of.
  • george daniel
    george daniel Posts: 12,096
    You know better than that. I didn't think it was necessary, but I guess I should have said, Until feed heavy doses of quality power they never produce what they are capable of.[/QUOTE]
    The Doctor has spoken!!
  • GlennDog
    GlennDog Posts: 3,158
    GENTLEMEN!
    Let's welcome the OP to CP the proper way . . . . Welcome Hauxon!
    Believe it or not, you will like OUR family of music/video enthusiasts!
    MERRY CHRISTMAS!!
    G
    Pre Cary SLP-05
    Power Rogue M180 Dark monos
    Mains Salk HT2-TL
    Rythmik F12
  • nguyendot
    Just try it and see how it sounds. No one can tell you if it sounds good to you.
    Main Surround -
  • hauxon
    hauxon Posts: 161
    Thanks you guys for all the replies. I mostly listen to alternative rock and jazz. My system is also connected to a TV set (in a 60m2 livingroom). I guess that 99% of the time 30w would be sufficient. I just need to drive decide if I want class A sound quality or sacrifice that somewhat for better allround performance.
    hauxon wrote: »
    I myself really like the sound of single ended class A, but if you get a higher power A/B type amp it doesn't mean a "sacrifice" in sound quality. There are plenty of stellar amps out there, far better than the Pioneer you mention, regardless of topology.
    Good luck with your search
  • megasat16
    megasat16 Posts: 3,521
    hauxon wrote: »
    Hello Hauxon,
    Welcome to Club Polk! It seems you are registered in Aug 2008 (a few months earlier than me) but with only two posts in all these years? You seriously need to ask more questions.
    Pioneer M-22 is a nice amp and while it may not be sufficient for your 2B, it will sounds great with some other efficient speakers.
    My C-21 Preamp is without a mate for many years and if you ever decide to sell the M-22, let me know. I am interested.
    Trying out Different Audio Cables is a Religious Affair. You don't discuss it with anyone. :redface::biggrin:
    Not Pass gear specifically but other higher powered amps
    I know that Jesse, the OP who is new doesn't know your particular philosophy so that's why I said I was playing devils advocate.
    We will have to agree to disagree as I just played Regina Spektor - All The Rowboats at a very high level and holy crap the walls were ratteling, my **** was tingling and the end percussion sounded like grenades going off right next to me. The last one actually scared me.
    No compression or lack of dynamics at all. I can only base it on what I'm experiencing and continue to experience in my own room with my own rig. All of what you speak, especially this inflammatory gem
    couldn't be farther from the truth in my case.
    P.s. I'll say it again as I have always said it, I don't mean to say it will work for everyone in every situation.
  • Schurkey
    Schurkey Posts: 2,122
    zingo wrote: »
    There ARE reasons that virtually all subwoofers have enormous wattage specs:
    1. Watts are cheap (when they're based on voltage moreso than current), and
    2. Subwoofer enclosures small enough to have appropriate WAF are horribly inefficient at low frequency. Paul Klipsch "got it" when he talked about the difficulty of miniaturizing a 30-hz soundwave; and therefore the size of the corner-horn. The same thing applies to other enclosure types, of course.
    It makes good sense from a business point of view to make the enclosure about the size of a pack of cigarettes, and then power the thing with a gigawatt of voltage (and the minimum current, because current means copper, and copper is expensive.)
