Bi-wire decision
Early B.
Early B. Posts: 7,900
Looking to bi-wire my Lsi7's. I'm trying to decide between Signal Cable's product and Canare Star Quad cable. I can get them both for the same price. Which one should I choose or does it even matter?
"God grooves with tubes."
Post edited by Early B. on
  • mantis
    mantis Posts: 17,322
    edited July 2004
    maybe not to many but It matters.
    Dan
  • steveinaz
    steveinaz Posts: 19,545
    edited July 2004
    Early,
    Both are respectable cables, it'll really come down to audition. If you don't have access to that scenario, try audioreview or something similar and look for re-occuring problems if applicable.
  • Pauly
    Pauly Posts: 4,519
    edited July 2004
    Call up Frank and order some Signal. Getting ready to order more for the center and the Sub :)
    Paul
    Life without music would
  • dorokusai
    dorokusai Posts: 25,576
    edited July 2004
    I would choose SC simply based on Frank's support for the forum, and the discount he gives its members.
  • Pauly
    Pauly Posts: 4,519
    edited July 2004
    Yup, great Guy to deal with...
  • Early B.
    edited July 2004
    Went with the Canare. Had some extra bulk cable laying around and got someone to terminate them with Vampire banana plugs and apply tech flex for $50. I have Frank's interconnects. Next purchase may be the Magic power cord for the amp in my 2-channel setup.
