Sub in a boat ?
gapple12
Hey Guys, I'm new here. Just picked up my first boat ( Monterey 190 ) and getting ready to put in a new sound system. My problem is sub-woofer location. My only real option is in the back engine compartment, which has tons of room, with a 12" sub for enough airspace. I MAYBE could fit an 10" or 8" Sub under the drivers console and a small box, but then leg room could suffer. The engine compartment has 4 air escapes for ports, 2 going forward along the side and 2 heat exits in the rear. I'm curious if I will be able to hear it good being inside there ? All my friends have theirs out in the open and they rock, Ive never seen one in a compartment. THANKS !!!
Red circle shows vents
Post edited by gapple12 on
It's look very good!thanks for your sharing!!
i would say 1 10".
usually the power handling is alot higher on them. -
how about a open air driver ?
Or build a isoberic clamshell design ( it will be 1/2 size cabinet ) thats nice
