Short MIT "tails". What do you support the Magic Boxes with?
GlennDog
the Very Good SRS 2s have binding posts that are mounted a little high. I wondering what you Guys n' Dolls use to elevate the MIT Magical Boxes? The tension on the cables is what concerning . . . as the cable tails are so short, the "boxes" hang and I'd prefer the interface boxes lay flat on the floor
G
G
Pre Cary SLP-05
Power Rogue M180 Dark monos
Mains Salk HT2-TL
Rythmik F12
Pre Cary SLP-05
Mains Salk HT2-TL
Rythmik F12
Post edited by GlennDog on
Let'em hang, won't harm a thing. Seriously, I had MIT Shotguns hanging off my office rig speakers for years, never a problem. If it really bothers you, velcro the boxes to the back of the speakers.Political Correctness'.........defined
President of Club Polk -
I am going to use a 2 coffee tables for my MIT Oracle Matrix HD 90's get here next week lol
I have seen these boxes. The velcro idea I think is the best because you can easily undo them if you have to move your set. Much better than heavy duty double face tape pads which would work but be more permanent.To relieve the pull and stress of gravity you could use plastic p-clamps or the kind of tyraps that have a mounting hole and just a short screw would do it also.
http://www.elecdirect.com/catalog/d688b565-602c-4371-a9be-2a64e641d3e7.aspx?gclid=CJamrLPlrLsCFYEDOgodZisAZQ2chl- Adcom GFA- 555-Onkyo P-3150v pre/amp- JVC-QL-A200 tt- Denon 1940 ci cdp- Adcom GFS-6 -Modded '87 SDA 2Bs - Dynamat Ext.- BH-5- X-Overs VR-3, RDO-194 tweeters, Larry's Rings, Speakon/Neutrik I/C- Cherry stain tops Advent Maestros,Ohm model E
Another suggestion....IF you order the cables new from MIT they can make them with extra long tails.Political Correctness'.........defined
Or if your looking for cheap, stack a couple small blocks of wood.....upside down cups.....if money is no object then pay Kate Upton to stand there and hold them. Betcha those cables will never sound so good plus you get the benefit of some really nice looking acoustical....um...panels.HT SYSTEM-
lsi 9's -
Use a stick-on pull-tie standoff (black) on the back of the speaker, to help support the box.Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2
Steve, I like your idea better than my velcro one.Political Correctness'.........defined
I use bungee cords...
