Pre/Pro
deronb1
deronb1 Posts: 5,021
edited December 2013 in Electronics
Been kickin around going with a pre/pro. Want to stay around 300.00 though. Can get a Parasound AVC-2500u in really good shape for 325.00 shipped. Anyone have experience with this piece? Will be mated to a Rotel RMB-1066. Also looking at a B&K Ref 50 for probably around the same cash.
Post edited by deronb1 on
  • aboroth00
    aboroth00 Posts: 1,106
    deronb1 wrote: »
    My first question is: what do you want to accomplish by getting a Pre/pro over a receiver?
    2Ch Tube Audio Convert
  • deronb1
    aboroth00 wrote: »
    Want to improve 2ch listening. Seems quality has degregated since using AVR as a pre.
  • deronb1
    Lasareath wrote: »
    Twice the price but worth the extra dough!
    http://www.outlawaudio.com/products/975.html
    That looks very interesting. I like bass management in 10Hz increments. Drives me nuts that the Pio starts at 50Hz and jumps to 80Hz.
  • BlueFox
    BlueFox Posts: 15,251
    aboroth00 wrote: »
    By leaving out the amps vendors can spend more on the pre part. At least that is the theory. When I replaced my Sony DA7100ES, used as a pre, with an Onkyo SC5509 pre I was amazed at the step up in sound quality.
  • deronb1
    Just want music to come first while having a decent sounding HT system. The Parasound PL / D Line drive amp and HCA1500a was killer for 2 ch music, but when I sold the 2Bs, just didn't need that much power anymore. The B&Ws sound terriffic, but it seems imaging and depth are lacking using the Pio as a pre. Want to get that back.
  • carvcom
    carvcom Posts: 240
    I think $325 is a bit high for the 2500u, I've seen them go for around $200. I have an AVC1800 that I love, very inexpensive.
    Have you looked at Lexicon? MC-1/DC-1 are in that ballpark, I also have an MC-4 that is really phenominal!
    They go for around $400.
    If you really like B&K, check out the Ref 30.
    I've had both the 50 & the 30, prefered the sound of the 30.
    My 2 cents!
    Good luck!
    S
  • deronb1
    DSkip wrote: »
    Why not save some dough and get the 105 then? Music will come first and you'll get all the digital prowess you need to run a home theater through your main rig. I try to find cheaper alternatives that I'd be happy with it but that thing has too much to offer.
    105?
  • aboroth00
    deronb1 wrote: »
    105?
    Oppo105? You can use it as a preamp for both HT and music with excellent Dac's.
    tonyb Posts: 33,069
    Not for 300 bucks he can't....lol
  • polklifer
    polklifer Posts: 40
    I have had several B&K pre/processors, all have worked really well for 2-channel, but the ref 50 is the winner because of the balanced inputs and outputs, build quality is excellent.
    I have found excellent synergy with my Adcom 5500/Ref 50 combo
    I paid $150 for my ref 50 w/remote, a screaming deal, so $300 plus seems pricey
    Good luck sir!
  • Lietuvis91
    Lietuvis91 Posts: 909
    Lasareath wrote: »
    I just bought one as a bstock unit for $399 2 months or so ago. Came looking brand new and replaced my marantz 7002 avr. I really really like it, because I really really enjoy listeningto it. The sound is much more natural and "live" when compared to the avr. It really took me a step closer to being at the concert as opposed to listening to it on a kick **** system. It's just a different overall musical experience. I have no other experiecne with any other dedicated pres. Given the sound quality and convenience of hdmi, especially ay the price of this thing, even if the B&K or whatever has marginally better sound, I don' think I'd care.
    Living Room 7.1 HT Rig:
    M70 | CS2 | M60 | Atrium5 - Surr. | SUB - Emotiva ULTRA12 + Tara Labs sub cable | Pioneer Elite VSX-52 | Parasound HCAs 1000A | Sony BDP-S790 | Belkin PureAV PF60 | MIT Exp2 Wires
    Bedroom 5.0 HT Rig (Music/Movies/Gaming) :
    LSi9 | LsiC | Lsi/fx | Marantz SR7002 | NAD T955 | Sony BDP-S360 | Belkin PureAV PF30 | AQ Blue Racer II ICs & AQ Type 4 wires | PS3
  • Lietuvis91
    Whatever your decision on chosing a pre, I personally really wish I had gone to a pre sooner, because I never really heard my lsi *sing* like this until I got a pre. I'm not sure I'll buy an avr ever again.
  • deronb1
    Think im gonna go with a pio sc series and be done with it
  • BlueFox
    258884 wrote: »
    Emotiva. Entry level is about 500.
    http://shop.emotiva.com/.........
    Nice first post. It almost qualifies as spam.
  • Lietuvis91
    deronb1 wrote: »
    If I were to do an avr the pio would definitely be it for me. I have one already and from all the ones I tried, I feel pio is the best match sonically for polk speakers.
  • gmcman
    gmcman Posts: 1,843
    polklifer wrote: »
    I paid $150 for my ref 50 w/remote, a screaming deal, so $300 plus seems pricey. Good luck sir!
    I'd say $150 is a screaming deal but $350 isn't too pricey IMO.
  • deronb1
    Lietuvis91 wrote: »
    The Pio sounds good with the B&Ws. The SC series may sound different, not sure really. Wan't an AVR with a warmish sound where I can control xover 60hz and 70hz as well. Drives me crazy that Pio skips from 50hz to 80hz. How much would it have cost em to include those two little settings?
  • gmcman
    gmcman Posts: 1,843
    Receiver: http://www.ebay.com/itm/B-K-AV-AVR307-7-1-Channel-150-Watt-Home-Theater-Receiver-Dolby-Pro-II-THX-etc-/221314759278?pt=Receivers_Tuners&hash=item3387633a6e
    You can go with a ST-202 or 202+, splurge for any of the 200.? amps with a Ref 30 or 50. A lot of bang for the buck.
