Receiver for tsi100s
Greenandwhite23
What are some receivers that you would recommend ($200 or under preferably) for Tsi100s. I want them for my room/basement and just want to play music from my phone.
Post edited by Greenandwhite23 on
Welcome to the forum and enjoy your music. It is the shopping season so why not look into a low end entry level Pioneer or Onkyo with air-play and other hook-ups to interface with your phone. Keep it under $300 or less because if you ever get into music in a bigger way your system will end up being passed along. Again, Welcome.Main Family Room: Sony 46 LCD, Sony Blue Ray, Sony DVD/VCR combo,Onkyo TXNR 708, Parasound 5250,
Living Room: Belkin PF60, Parasound HCA2200, MIT ProlineEXP balanced IC's,Emotiva XDA-1 DAC/Pre,Emotiva ERC2 transport,MIT AVT2, Polk LSI 9's. -
Thanks for the reply. Do you think that the onkyo tx-8020 would be a good purchase?
Rochester NY
http://www.accessories4less.com/make-a-store/item/DENAVR1612/DENON-AVR-1612-5.1-Channel-A/V-Home-Theater-Receiver/1.html#!specifications
http://www.accessories4less.com/make-a-store/item/ONKTXNR414/Onkyo-TX-NR414-5.1-Home-Theater-3-D-Ready-Network-A/V-Receiver/1.html
http://www.accessories4less.com/make-a-store/item/ONKTXNR525/ONKYO-TX-NR525-5.2-Channel-Network-A/V-Receiver/1.htmlPOLK SDA 2.3 TLS BOUGHT NEW IN 1990, Gimpod/Sonic Caps/Mills RDO-198
ONKYO HT RC-360 SONY BDP S590 TECHNICS SL BD-1 -
Welcome to Club Polk!
For two channel music from your phone you won't need much more than the $100 Sherwood Dskip referenced above. It has everything you need and will sound good enough with those entry speakers.
If you want to go upscale a bit. Any STEREO receiver by Marantz or Harman Kardon will do you, Onkyos are also good.
A Marantz SR-4023
Harman Kardon 3390 or the more powerful 3490 (if you can afford it)
Onkyo TX-8050 would also be good
The Onkyo and the 3490 have DACs for Digital audio connections so that's a PLUS!
Thanks for all the replies. I'm new to this, but if I buy something like the yamaha rx- v375 I can hook up the speakers to my tv, ps4, laptopand/or phone?
But as I said before these are primarily for music
Almost none of the stereo receivers have and HDMI out. Which is what you would need to hook to a PS4, and a newer laptop if it has an HDMI port.
So what you really need is an "entry" level AVR (Audio-Video Receiver). The Yamaha you mention should have the appropriate requirements for 5 channel surround plus .1 for the sub or 5.1 surround! And allow you to hook up your PS4 and laptop to it then run ONE HDMI wire from the Yamaha to the TV and use the Yamaha as the switching unit.
So would something like the onyko tx sr313 be a good entry level avr? (Same price as the yamaha avr)
Any new AVR has the appropriate HDMI specs for what you need. That Onkyo would be fine as well. The only thing to consider is that you're stuck with whatever you purchase for now.
Higher model AVRs often have Pre-outs that can be used to improve power and audio performance through the addition of external amps. But if you're just going to power bookshelves that are fairly efficient, the Onkyo is fine!
Have you looked at www.accessories4less.com They have refurb units that come with a ONE year warranty and are often bargain priced. They sell Onkyo, Marantz, and Denon, etc.
Thanks for the info. I checked that site and they have the onyko for only $130 opposed to $200 on amazon.
Edit
Edit
Best bang for the buck go to www.c2g.com they have 12awg in a nice blue jacket with gold banana plug ends. price range on distance needed.....IE 10' cost around $14Family Room HT 7.2/i]:Vizio Oled55h1 Pioneer Elite SC-LX502 Pioneer Elite BDP 85FD Eversolo DMP A6 Panamax M5300-EXSpeakers Fronts Fluance XF8L Center Polk Audio S35 Side Surrounds Fluance bipolar Rear Surrounds FluanceXF8 Bookshelf Subs SVS PB4000 x2 Living room 2ch: Crown Xli 1500 amp x2, Teac EQ MKII FX Audio X6 Mk II DAC Squeezebox Touch Polk Audio R700 Speakers Panamax M5100-EXOffice media room:Vizio M50Q6 50" Pioneer Elite VSX LX301 Eversolo DMP-A6 Polkaudio R600 Towers Polkaudio Center R350 Panamax M4300 Monoprice 12" subMaster bedroom:Vizio M55Q7 Pioneer Elite VSX LX302 Pioneer Elite BDP 85FD Squeezebox Touch Fluance Signature Bookshelf fronts, Rears Fluance Signature Bipolar Polk Audio CS10 center Monoprice 12" sub Panamax M5300-EX
Higher model AVRs often have Pre-outs that can be used to improve power and audio performance through the addition of external amps. But if you're just going to power bookshelves that are fairly efficient, the Onkyo is fine!eleatherjackets leather jackets
spanish-made-easy www.spanish-made-easy.com
business analyst training business analyst training
000-667 braindumps 000-667 braindumps -
I ran them with my trusty Pioneer 520-K has many hdmi inputs along with audio features dts-neo-etc..
sounded great. Received a lot of compliments with those on sound with movie/music.
I am very pleased with it performance of the quality on both audio and video
I recently put them to the back
And have Polk M70 SII in front. Now need to upgrade lol.
I was however going to buy another for my best friend and maybe mother in-law
Perfect entry level I think.
EBay has like 3 @auction for like 49 shipped(so far) with a 14 day return policy
Even Wal-Mart carries the Pioneer 522-k or maybe it's the 523Polk Lsi9
Polk LsiC
Polk Fxi3
Pioneer SC-1222
Parasound 1200 II w/ Kimber Kable HERO + 4TC
SVS PB12-NSD (Bash)
PS4
Sharp Aquos 55"
"If your BOLD enough to try it,
your BOLD enough to make it happen"
