Can you convert LSI15 between left and right?
johnobuttons
Has anyone ever tried converting an LSI15 left speaker to a right speaker.
Seems like it might be possible.
John
John
Post edited by johnobuttons on
Dont think so since the tweeter position is different between the two so you would need to re-drill the new position and fill in the old one.
I would almost just call Polk and see if they have a cabinet they can sell you"....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963) -
I have never seen a cut away but the framing inside coming up to the dual ports would inhibit the relocation of the tweeter2-channel: Modwright KWI-200 Integrated, Dynaudio C1-II Signatures
johnobuttons wrote: »Has anyone ever tried converting an LSI15 left speaker to a right speaker.
John
Maybe some more info as to WHY someone would want to do that ? That would only be possible on mirrored pairs of speakers, not dedicated left and right.HT SYSTEM-
lsi 9's -
Am I missing something here? There are big holes in the side that are on different sides for left and right. What do you do about those?Front - Polk LSiM 705, Center - Polk LSiM 704c, Rear - Polk LSi 7
Subwoofer - Epik Legend
Receiver (as Preamp) - Sony STR-DA3400 ES
Amplifier - Outlaw 7125
Television - 58" Samsung Plasma PN58B860
Blu Ray - OPPO BDP 83 -
Your not missing anything, and your right. The Op asked...we answered. A mirrored pair of speakers, meaning identical to each other, is no problem switching left to right or visa-versa. Dedicated left and right speakers are built from the ground up that way, cabinets, placement of drivers. To try and change that would mean building a new speaker. Some have switched dedicated speakers so that side firing woofer throws to the inside rather than the out, which seems to work ok for some.HT SYSTEM-
lsi 9's -
I was thinking the same thing.2 ChannelTurntable - VPI Classic 2/Ortofon 2M BlueAmplification - Rogue Audio Cronus Magnum II, Parks Audio Budgie PhonoSpeakers - GoldenEar Triton 17.2 Home TheaterDenon AVR-X3300W; Rotel RMB-1066; Klipsch RP-280F's, Klipsch RP-450C, Polk FXi3's, Polk RC60i; Dual SVS PB 2000's; BenQ HT2050; Elite Screens 120"Man CaveTurntable - Pro-Ject 2.9 Wood/Grado GoldAmplification - Dared SL2000a, McCormack DNA 0.5 DeluxeCD: Cambridge AudioSpeakers - Wharfedale Linton 85th Anniversary; LSiM 703; SDA 2A -
Thanks for the help. LSI15 left speakers are selling really cheap on ebay, but haven't seen right speakers.
I haven't seen how the LSI15 is put together and had wondered if woofer portion could be turned 180 degrees so woofer would fire in.
I can imagine how it would likely be impossible. -
It would not be worth your time or money; it would be cheaper to buy a stereo pair.
